MWLoyale Posted May 26, 2019 Share Posted May 26, 2019 I have a 93 loyale Would these bushigs work for the control arms? Has anyone ever got them? https://www.amazon.com/20201Aa000-Front-Bushing-Subaru-Febest/dp/B00DMA71MU/ref=pd_bxgy_263_img_3/145-4243497-3177661?_encoding=UTF8&pd_rd_i=B00DMA71MU&pd_rd_r=32de795f-7f51-11e9-bbb8-afc81129452f&pd_rd_w=TFgVE&pd_rd_wg=XM35G&pf_rd_p=a2006322-0bc0-4db9-a08e-d168c18ce6f0&pf_rd_r=T5KBCBK22FMEFDGNS00G&psc=1&refRID=T5KBCBK22FMEFDGNS00G https://www.amazon.com/FEBEST-SAB-BHRL-Control-Arm-Bushing/dp/B00R97HJNS/ref=au_as_r?_encoding=UTF8&Make=Subaru|13&Model=Loyale|65&Year=1993|1993&ie=UTF8&n=15684181&s=automotive&vehicleId=1&vehicleType=automotive It looks like an ea82 control arm, but reviews say otherwise "fits 2002 outback" ... Link to comment Share on other sites More sharing options...
FerGloyale Posted May 27, 2019 Share Posted May 27, 2019 No that's for EJ platform cars (Leg, Imp, For, etc) Link to comment Share on other sites More sharing options...
MWLoyale Posted May 27, 2019 Author Share Posted May 27, 2019 Are there any options i have for replacing these bushings? Link to comment Share on other sites More sharing options...
BEECHBM69 Posted May 27, 2019 Share Posted May 27, 2019 (edited) 3 hours ago, MWLoyale said: Are there any options i have for replacing these bushings? I want to say somebody was able to match up some poly bushings from an aftermarket company somewhere. I'll poke around and see if I can find the thread on it. Dan On edit: Found this thread, older thread, and not sure if Amir is still there, but the a search of the number brings a bunch of hits. Good luck! Edited May 27, 2019 by BEECHBM69 Found info Link to comment Share on other sites More sharing options...
czny Posted May 27, 2019 Share Posted May 27, 2019 https://www.ultimatesubaru.org/forum/topic/134590-diy-bushing-replacement/ There are Superpro bushings still available but you must be patient for them from Aus. Search for Superpro in this forum. Look here too. 5th post first page. Energy Suspension bushings. https://www.ultimatesubaru.org/forum/topic/131364-87-gl-4wd-wagon-czny/ Link to comment Share on other sites More sharing options...
FerGloyale Posted May 27, 2019 Share Posted May 27, 2019 1 minute ago, czny said: https://www.ultimatesubaru.org/forum/topic/134590-diy-bushing-replacement/ There are Superpro bushings still available but you must be patient for them from Aus. Search for Superpro in this forum. Look here too. 5th post first page. Energy Suspension bushings. https://www.ultimatesubaru.org/forum/topic/131364-87-gl-4wd-wagon-czny/ I knew you were the man for this one. 1 Link to comment Share on other sites More sharing options...
czny Posted May 28, 2019 Share Posted May 28, 2019 (edited) Front bushings https://www.ebay.com/itm/SuperPro-Control-Arm-Lower-Inner-Bushing-Kit-Front-for-1981-1986-Subaru-Brumby/264304776028?hash=item3d89cad35c:g:Vt0AAOSwaANcyNN8 https://www.ebay.com/itm/SuperPro-Control-Arm-Lower-Inner-Bushing-Kit-Front-for-1981-1986-Subaru-Brumby/283468751142?hash=item42000de126:g:U9oAAOSwEZdcyNK1 Rear bushings https://www.ebay.com/itm/SuperPro-Axle-Alignment-Trailing-Arm-Bushing-Kit-Rear-for-1979-1994-Subaru-Leone/283468762117?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D57921%26meid%3Dd5984c730b32448385cc2bb4439a6a57%26pid%3D100005%26rk%3D5%26rkt%3D12%26sd%3D173716101380%26itm%3D283468762117&_trksid=p2047675.c100005.m1851 Edited May 28, 2019 by czny Link to comment Share on other sites More sharing options...
carfreak85 Posted May 28, 2019 Share Posted May 28, 2019 18 hours ago, czny said: There are Superpro bushings still available but you must be patient for them from Aus. SuperPro USA is located in Colorado, I've bought multiple sets of bushings from them in the past couple years. Link to comment Share on other sites More sharing options...
czny Posted May 28, 2019 Share Posted May 28, 2019 1 hour ago, carfreak85 said: SuperPro USA is located in Colorado, I've bought multiple sets of bushings from them in the past couple years. http://www.superprousa.com/where-to-buy/ Link to comment Share on other sites More sharing options...
carfreak85 Posted May 28, 2019 Share Posted May 28, 2019 I've spoken to the guy who runs the outfit. If a local dealer doesn't carry the part you need (pretty common for the EAs) they'll ship it directly. I'm really pleased with their service and quick responses. Link to comment Share on other sites More sharing options...
Steptoe Posted May 30, 2019 Share Posted May 30, 2019 Am I missing something? I clicked on the eBay link for rear bushings above a few posts and pictures and describes 8 Bushes 4 Tubes Surely only one tube and two bushes per trailing/ transverse arm? Only one arm per side Looks like kit does two cars? Link to comment Share on other sites More sharing options...
carfreak85 Posted May 30, 2019 Share Posted May 30, 2019 The bushings are probably split to allow easy installation, don't have to press the new ones in. Four bushing halves & two tubes per arm, for the two attachment points per arm. Link to comment Share on other sites More sharing options...
czny Posted May 30, 2019 Share Posted May 30, 2019 4 hours ago, carfreak85 said: The bushings are probably split to allow easy installation, don't have to press the new ones in. Four bushing halves & two tubes per arm, for the two attachment points per arm. Right. Two each trailing arm, #9 in link & two each for the slotted toe-in plate mounted outboard on the cross member, #8 in link. https://www.subarupartsamerica.com/parts/1989/SUBARU/GL/Turbo/?siteid=216122&vehicleid=45477&diagram=758260 Four bushing halves & two tubes per side. Link to comment Share on other sites More sharing options...
