MWLoyale Posted June 12, 2019 Share Posted June 12, 2019 Has anyone used group n motor mounts on their ea82? They look very similar to the ones on my 1.8L. Link to comment Share on other sites More sharing options...
FerGloyale Posted June 12, 2019 Share Posted June 12, 2019 you could make them work by drilling new holes in the old EA upper mounting plate. But it's not a direct fit. Link to comment Share on other sites More sharing options...
MWLoyale Posted June 12, 2019 Author Share Posted June 12, 2019 Thats what i had thought. Thanks G On 6/12/2019 at 9:32 PM, FerGloyale said: you could make them work by drilling new holes in the old EA upper mounting plate. But it's not a direct fit. Expand Link to comment Share on other sites More sharing options...
88SubieSnack Posted June 21, 2019 Share Posted June 21, 2019 Interested if you went this route? I'm in need of new mounts however I'm brainstorming more stiff mount ideas that require minor modifying. Link to comment Share on other sites More sharing options...
MWLoyale Posted June 24, 2019 Author Share Posted June 24, 2019 I did not, i ended up buying a pair off ebay that ended up being westar brand. I paid cheap for em, i think $40 for money saving purposes. I just got an ea82 block with 101k from upullit from an 89 dl and i plan on using group n mounts on that. On 6/21/2019 at 2:48 PM, 88SubieSnack said: Interested if you went this route? I'm in need of new mounts however I'm brainstorming more stiff mount ideas that require minor modifying. Expand I would have no hesitation suggesting using group n mounts on an ea82, but i havent done it so i cant be sure. Like G said, it only requires a hole to be drilled. The mounts look identical other than the extra stud on ej mounts. Link to comment Share on other sites More sharing options...
