jonathan909 Posted June 22, 2019 Share Posted June 22, 2019 I've just rebuilt the AC system (everything but the evaporator) from junkyard parts in a car that PO had stripped it of (he's originally from Africa and thus indifferent to air conditioning). Prior to attempting to charge it up, I figured I'd do a smart thing (for a change) and see if it leaks. Hung the manifold gauge, hooked up the vacuum pump, and ran it down. As soon as I closed the valve to the pump, though, the system quickly rose back to atmosphere. So how do I track down what appears to be a substantial leak? Pressure it up (with air through the gauge) and start squirting Snoop all over the connections? If so, to what pressure? If not, how? And if that doesn't turn anything up, how does one ID leaks in the evaporator or condenser? Answers to relevant questions I'm too dim to ask also welcome. Link to comment Share on other sites More sharing options...
Jadu108 Posted June 22, 2019 Share Posted June 22, 2019 Uv dye and a black light is my go to. Your method would work as well i think. Link to comment Share on other sites More sharing options...
Jadu108 Posted June 22, 2019 Share Posted June 22, 2019 But iv dye is the best. With a blacklight youll see it instantly... And its really gokd for checking the condensor, etc. As far as squriting soap water or snoop or whatever, id pressure the system to normal psi as thats what youre gonna have the system at anyway... Link to comment Share on other sites More sharing options...
jonathan909 Posted June 22, 2019 Author Share Posted June 22, 2019 (edited) Okay, but doesn't UV dye imply adding refrigerant to a known-leaky system? Or is there "standalone" dye available that you inject into the system, then pressure it up with air? Edited June 22, 2019 by jonathan909 Link to comment Share on other sites More sharing options...
Jadu108 Posted June 22, 2019 Share Posted June 22, 2019 A lot of times they come alrdy mixed in the refigerant, but you can buy stand alone dye... Try Advanced Auto? Last place i saw it. Link to comment Share on other sites More sharing options...
jonathan909 Posted June 22, 2019 Author Share Posted June 22, 2019 No "Advanced Auto" in Soviet Canuckistan, but I get the point. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 22, 2019 Share Posted June 22, 2019 (edited) maybe you'll get lucky and could hear the leak? perhaps get some tube of some type to 'sweep' all the joints and the condeser , etc. Edited June 22, 2019 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
