I was considering forking out $$$ once again for a group N (STI) transmission mount for the Legacy, as I bought one a few years ago and fitted it to the Forester with very happy results.
Then I found the remains of the windshield adhesive sealant I had recently used to toughen up the Vivio’s failing engine mounts, and I then dug out the Forester’s old soft transmission mount, still in one piece...
....So I am experimenting with...
One original Forester SF trans mount,
Two unused hard rubber bushes from a Fiat Panda’s trailing arms,
1/2 tube of windshield adhesive/sealant.
-Thoroughly clean and degrease the mount, and force in the bushes (bench vise did the trick):
-Tape up one side to prevent seepage:
-Squeeze in sealant from the open side as thoroughly as possible:
-Do what you will with the excess, and leave to cure for a few weeks:
When it is cured I shall remove the Legacy’s existing mount and compare them both in the hand, before fitting and coming back with an update.
I am expecting a firmer mount, though not as stiff as the real STI component.
I do not mind a little extra nvh, as it will likely muffle the rattling trim.
The SF Forester with the real STI mount only really showed extra cabin noise as a growl under heavy acceleration- sweet!
The good lady did not notice any change except for the ‘stiffer knob’ . Obviously.
The Legacy feels sloppy in comparison with its 22yo rubber.
Edited by Mitchy
This is definitely the cheapest option;
The sealant already paid for itself in the repair of a full set of another Subaru’s engine mounts, the two bushes were left-overs from a resto project, and the mount itself is also a left-over, until now sitting on my shelf waiting to be thrown out.
Time will tell if it is successful.
I may end up putting the DIY part on the beater Forester and using the nice newish STI part (presently on the Forry) on the Legacy instead. Its such a quick and simple job.
Edited by Mitchy
90 degrees today so I am hiding under the cars-
As I was underneath the Forester changing oil, I thought I might as well take the fairly new genuine STI mount off and swap back the now-modded OEM item.
The Forester has a little more room to work underneath than the Legacy, so the Legacy is now getting the real STI group N part, hopefully never to be changed again....
If the modded one fails it is now more convenient to change it on the Forester!
Plus I now have the original Legacy mount, which I may try GeneralDisorder’s tip using urethane:
  On 6/25/2019 at 5:14 PM, GeneralDisorder said:
It would be better and cleaner to use pourable urethane. I've used the pourable silicone and urethane from smooth-on and the stuff is amazing.
Expand
So now for a quick bolt-up job on the Legacy with the harder mount, and time go for a spin!!
Group N mount vs. original Legacy:
Edited by Mitchy
As expected, driving the Legacy is transformed by this simple and highly-recommended modification.
The genuine STI (group N) part provides more precise gear changes, gear stick stiffness, the car feels more stable as the transmission is now properly ‘held’ against the g-forces in corners, over bumps on our track, and various other general sounds of ‘looseness’ have been eradicated.
If that was not enough, the classic lurching at low speeds whilst coasting in gear has been reduced by about 3/4.
If one can handle the NVH;  at idle and gentle revs/ low speed, the difference is unnoticeable, but accelerating at and above 3000rpm there is a loud growl. (Smile) This then disappears when cruising at high speed in 5th, though there is a negligible rise in engine noise overall.
I love it, I can hear the engine better which I prefer as I can monitor my cars health ‘by ear’, and the modification has as a bonus removed some unwanted rubs and clunks from underneath, those typical noises which could have been.... faulty engine mounts...exhaust hangers... suspension bushes...track control arms.... etc. etc.
Edited by Mitchy
