ashawver73 Posted June 30, 2019 Share Posted June 30, 2019 My outback is saying misfire on cylinder 3 & 4. Shop says try unplugging MAF sensor while acting up, and that will tell me if that's the problem. Can't find it for the life of me. They sell MAF sensors for this year, but I see in various forums that there is no MAF sensor in this model. Please help. I've found the MAP sensor. I also replaced plugs and wires. Going to replace coil pack next. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 1, 2019 Share Posted July 1, 2019 what car do you have? My first guess would have been coil pack due to waste spark ignition - other possibilities are ; plugs, plug wires, oil on plug wire boots from leaking valve cover gaskets. Link to comment Share on other sites More sharing options...
ashawver73 Posted July 1, 2019 Author Share Posted July 1, 2019 I have a 2004 outback base model. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 1, 2019 Share Posted July 1, 2019 miles on car? new to you? well maintained or unknown or neglected....? Link to comment Share on other sites More sharing options...
ashawver73 Posted July 1, 2019 Author Share Posted July 1, 2019 162xxx, I've had it for a few months. Bought used. Unknown maintenance. Looks pretty well taken care of Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 1, 2019 Share Posted July 1, 2019 well, you can try a coil pack I guess but, you should try to catch-up on any maintenance or repair items. Could be old plugs..... Link to comment Share on other sites More sharing options...
ashawver73 Posted July 1, 2019 Author Share Posted July 1, 2019 My post says I replaced the plugs and wires. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 1, 2019 Share Posted July 1, 2019 so it does, my bad. NGK plugs?, OEM wires? no oil on the old boots? if so, I think the coil pack is a very likely source of the problem. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 2, 2019 Share Posted July 2, 2019 Don't diagnose with Visa. Check compression, injector pulse, and spark on all four cylinders. GD Link to comment Share on other sites More sharing options...
wtdash Posted July 2, 2019 Share Posted July 2, 2019 NGK on the plugs/wires? Not sure if the '04 were as picky as the earlier models...but why tempt the fates. 2000-2004 Outback had NO MAF, so you're not blind. :-) It's an EJ251 vs EJ253 thing (kinda) Only the turbocharged models had a MAF in '04 - STI, WRX, FXT, Baja turbo...IIRC. 1 Link to comment Share on other sites More sharing options...
ashawver73 Posted July 3, 2019 Author Share Posted July 3, 2019 Well, got the cylinder 3&4 misfire gone. Cleaned the PCV valve. But now, flashing AT oil temp light. I had unplugged all the sensors around where I was told the MAF was, looking for it. Cleaned the connections with electrical connector cleaning spray and plugged back in. Now the flashing light that won’t quit. Flashes once per second. No CEL. Link to comment Share on other sites More sharing options...
wtdash Posted July 3, 2019 Share Posted July 3, 2019 (edited) You've got a code stored in the TCM / TCU / AT computer. You'll need to search on here about how to read the TCM - AT computer - codes. May be under "secret handshake" . Yes, seriously. On the pre-'99 models it was a series of steps that would then cause the AT temp light to flash the stored code. Repeat - the flashing tells you there's a code(s) stored but not what the issue is. We can't help until you get the actual code. Or you find what needs reconnected?? Edited July 3, 2019 by wtdash Link to comment Share on other sites More sharing options...
ashawver73 Posted July 3, 2019 Author Share Posted July 3, 2019 Yep, finally got the long, convoluted method to work. It’s 31, throttle sensor? Link to comment Share on other sites More sharing options...
ashawver73 Posted July 3, 2019 Author Share Posted July 3, 2019 I did take that out and put back while looking for the MAF. Could I have done something wrong when putting it back? Link to comment Share on other sites More sharing options...
