ea82 performance increase
ngk plugs, acell coil, cut out bottom of air box and run a k-n filter , gap your plugs at at .45 , 2 inch pipe from the cat back ,turbo muffler , no center cat , if you have a turbo motor , i call it the big football cat cut it out and run 2 in pipe back , there might be a few more like bumping up your timming ,
Do you know the part no. or type of NGK plug to run?
