Dom Posted July 9, 2019 Share Posted July 9, 2019 Will an ej22 out of a 91 legacy fit into a 91 justy? Will it just drop in and bolt up to the justy transmission? How much of the electronics will have to be changed Ecuador, control modules and such? Link to comment Share on other sites More sharing options...
Numbchux Posted July 9, 2019 Share Posted July 9, 2019 No Justy uses an inline engine, transversely-mounted. About as different as it's possible to be and still be a 4-cylinder. Link to comment Share on other sites More sharing options...
FerGloyale Posted July 9, 2019 Share Posted July 9, 2019 Not even close. Justy uses 3 cyl, transverse mounted. EJ22 is longitude mounted. MAYBE with lots of fab, EJ22 and a matching trans could be hooked up to Justy axles. Link to comment Share on other sites More sharing options...
Dom Posted July 10, 2019 Author Share Posted July 10, 2019 Ok that’s more work than I want to do. Too bad it would have been cool. Thanks Link to comment Share on other sites More sharing options...
Numbchux Posted July 10, 2019 Share Posted July 10, 2019 On 7/9/2019 at 7:55 PM, FerGloyale said: Not even close. Justy uses 3 cyl, transverse mounted. EJ22 is longitude mounted. MAYBE with lots of fab, EJ22 and a matching trans could be hooked up to Justy axles. Expand Ha. I forgot Justy's use a 3-cyl....good call Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted July 10, 2019 Share Posted July 10, 2019 (edited) certainly far from plug and play but, maybe some other small xverse engine could make a fun project? smart car, or honda Fit or motorcycle engine.....? any 3 cyl JDM engines? Edited July 10, 2019 by 1 Lucky Texan Link to comment Share on other sites More sharing options...
Numbchux Posted July 10, 2019 Share Posted July 10, 2019 On 7/10/2019 at 6:52 PM, 1 Lucky Texan said: certainly far from plug and play but, maybe some other small xverse engine could make a fun project? smart car, or honda Fit or motorcycle engine.....? any 3 cyl JDM engines? Expand Yea, with some mounts and axles (and wiring, and plumbing...all the normal swap stuff), a person could put almost any transverse FWD drivetrain in one. Wouldn't even be terribly hard to keep it AWD (custom driveshaft, finding a rear diff in the right ratio). People put VTEC Honda engines in old Minis fairly regularly.... Link to comment Share on other sites More sharing options...
czny Posted July 10, 2019 Share Posted July 10, 2019 1991 Pontiac Sunfire Quad 4 drivetrain would be more than enough: https://en.wikipedia.org/wiki/Quad_4_engine#LD2 Link to comment Share on other sites More sharing options...
