impreza Posted July 19, 2019 Share Posted July 19, 2019 hello everyone... i have an impreza 2008 hatchback 2.0L 4x4 that i converted from 4 speed AT to 5 speed manual. i solved all the mechanical adaption challenges and the car is driving... my problem is with the throttle, it doesn't open over 30% (opens 100% and immediately closes 70%) .It is actually stuck in safe mode and accelerates slowly because the AT gearbox is disconnected. i replaced the ecu with the complete lock set (ecu, body control unit, instrument panel, keys & switch) taken from the same model but with a manual gearbox. unfortunately it doesn't help and the issue remains the same, the clutch and neutral switches are also missing... my suspicion is the harnesses are different between AT & MT models. when connecting lunch diagnostic to OBD the trouble code is: P0600 serial communication link... I would appreciate any advice to solve this problem Link to comment Share on other sites More sharing options...
el_freddo Posted July 22, 2019 Share Posted July 22, 2019 You’re going to have to trick the ECU to think that the auto is still there I reckon. I know this works on earlier models but really don’t know with the later stuff. Why didn’t you just swap for a manual vehicle? Cheers Bennie Link to comment Share on other sites More sharing options...
impreza Posted July 22, 2019 Author Share Posted July 22, 2019 hi benny. i dident swap to manual car because they almost dont exist in in our country... Link to comment Share on other sites More sharing options...
el_freddo Posted July 22, 2019 Share Posted July 22, 2019 9 hours ago, impreza said: hi benny. i dident swap to manual car because they almost dont exist in in our country... Fair enough! Do some google searches, I’m sure it’s been documented somewhere as to how you trick the ECU. Otherwise the other way to go is aftermarket ECU if you’re that way inclined. Tunability goes through the roof. Cheers Bennie Link to comment Share on other sites More sharing options...
