EA-81 Heads
On ‎7‎/‎20‎/‎2019 at 5:32 PM, FerGloyale said:
Yeah, but FI heads on;y came on turbo cars.
So the compression will be low if the pistons are not swapped too.
The heads have no change on the compression.  EA81Ts have lower compression pistons, the combustion chamber volume is identical, carb or turbo.
Right, so unless he swaps the pistons, it will be low compression.  That's what I meant.
