divinicus Posted July 25, 2019 Share Posted July 25, 2019 Hi All! I'm still having trouble starting my 83 Brat GL, I thought it was weather related during the winter months here in NYC, but it's still happening in this hot, hot summer! I bought a $300 800 cca Odyssey battery, changed all the cables, and the car does eventually start, it's just very finicky from a fresh start. I was at a parts house last night and a guy heard me having the issue and said there is something called a pickup coil under the distributor, or that is part of it. Does that make any sense to anyone? Any help on this greatly appreciated. Once the engine is started and warms up, restarting it isn't an issue. It's just the fresh start. Thanks again! Link to comment Share on other sites More sharing options...
DaveT Posted July 25, 2019 Share Posted July 25, 2019 Is the choke working? Link to comment Share on other sites More sharing options...
el_freddo Posted July 25, 2019 Share Posted July 25, 2019 The coil the dude mentioned is used with points. If you have electronic ignition in the dizzy (eg no points in the dizzy) then you don’t need this coil thingymajiga. Cheers Bennie Link to comment Share on other sites More sharing options...
88SubGL Posted July 26, 2019 Share Posted July 26, 2019 Is it turning over ok, just not getting fire or is it having trouble turning over? With everything that you mentioned that you had changed, it sounds like you were having an issue with it turning over. Are you the same issue or is it something new? Link to comment Share on other sites More sharing options...
divinicus Posted July 26, 2019 Author Share Posted July 26, 2019 13 minutes ago, 88SubGL said: Is it turning over ok, just not getting fire or is it having trouble turning over? With everything that you mentioned that you had changed, it sounds like you were having an issue with it turning over. Are you the same issue or is it something new? It's turning over ok, but struggling sometimes. Thanks for your help! Link to comment Share on other sites More sharing options...
