fuji4x4 Posted July 31, 2019 Share Posted July 31, 2019 Alright guys so I've been lurking on these threads for a while but I've recently ran into an issue with my build that required me to post a question. I have an 84 GL 4WD and it seems to be that front struts are completely obsolete besides Gabriel struts on eBay for $300. Now do the next gen struts from the loyals fit directly without modification? Or any other Subaru? From my digging in the forums I've found a lot on 3rd gen/loyal struts but almost nothing on 2nd gen. Link to comment Share on other sites More sharing options...
fuji4x4 Posted July 31, 2019 Author Share Posted July 31, 2019 My front suspension is so springy that the car bounces down far enough to smack the CV axles lol! Not fun! Link to comment Share on other sites More sharing options...
idosubaru Posted July 31, 2019 Share Posted July 31, 2019 (edited) Don't look for entire assemblies - they work better for other manufacturers but are generally low grade options for Subaru's. Get KYB struts, they're preferred replacements for Subaru's and inexpensive. I think they're like $20 for a brat! Pocket change for the best available option! Edited July 31, 2019 by idosubaru Link to comment Share on other sites More sharing options...
charles_thomas Posted July 31, 2019 Share Posted July 31, 2019 Those work well, if it is bouncing that far, I would lean towards checking springs as well. If you have added any weight to the front, it might be too much for the stock springs, they don't like it. One options, although it does require some small mods, (redrill tophat screw holes, mount brake cable at bottom differently) is to use ea82 front struts, they are much easier to find, and are *fairly* close in size, etc. I know you said without any mods, but it is a cheap option to consider, and a few small holes is not bad for the payout, IMO. Here is a pic, I ran them in my '78 brat that I had for quite a while. Went from ea71 style straight to ea82 struts. Link to comment Share on other sites More sharing options...
Steptoe Posted August 2, 2019 Share Posted August 2, 2019 Have you tried genuine supply? If you have the part number they might be able to find available. I have Gen3, as in EA82 front struts in EA81 body. Took a little thought to make it work, holes in correct spot for three studs and a little Emery paper to make strut fit in hub axle Link to comment Share on other sites More sharing options...
