Steptoe Posted August 14, 2019 Share Posted August 14, 2019 Any of the collective genius know of a hose clamp that has a different angle screw from std clamps, sort of like this looks... It is my attempt at a mock up of what we need in 14 mm for the coolant hose 7.5mm ID (14 mm OD) that goes from the block to inlet manifold below thermostat gasket. On the movie and turbo , the manifold has to come off to replace the hose due to hose clamp access If we had a different axis screw clamp ... Quote Link to comment Share on other sites More sharing options...
Steptoe Posted August 14, 2019 Author Share Posted August 14, 2019 Just measured a Subaru shaped hose with stated ID of 7.5 mm and 14 mm OD The pipe fitting it is intended to fit I think, is 6.70 mm but the onion bulge like the mid point of making a double flare is the 7.5 mm section, not the clamping section Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 14, 2019 Share Posted August 14, 2019 spring clips can be grabbed/operated from the side. 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted August 14, 2019 Share Posted August 14, 2019 Try a search on McMastercarr.com, they might have something. Quote Link to comment Share on other sites More sharing options...
FerGloyale Posted August 14, 2019 Share Posted August 14, 2019 it can be done with regular clamps using long skinny screwdriver, or 1/4 drive, thinwall socket. Provided it wasn't put together with teh clamp oriented in a way that you can't access after manifold is on. 1 Quote Link to comment Share on other sites More sharing options...
Steptoe Posted August 14, 2019 Author Share Posted August 14, 2019 Thinking back now, I used to set this hose clamp so it can be done from the side, but in hurry to fit manifold with possibly gasket goo setting and just that awkwardness if it's umbilical cord attached - forgot, and set screw in vertically Interestingly found a patent from the 1940s that incorporated bevel gears etc and also the classic car era of a tangential screw. Gonna see if I can get in there with some brutal tools.... Thanks for suggestion Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 15, 2019 Share Posted August 15, 2019 maybe find one like this: https://www.candirect.eu/UNEX-hose-clamp-CNS-up-to-21-mm Quote Link to comment Share on other sites More sharing options...
Steptoe Posted August 15, 2019 Author Share Posted August 15, 2019 An answer came back to me locally for the right angle application - use a spanner on the clamps screw head - gives a right angle fastening approach. Manifold came off in 30 minutes. Absolutely clean manifold bolts ! I used stainless and copper grease. Someone once commented stainless could be worse than Subaru's originals and corrode more, not so this time I am happy to say. I used hose 8076.07021 instead of correct block to thermostat hose due to lack of local availability 7.5*14*80*80 Quote Link to comment Share on other sites More sharing options...
Steptoe Posted August 15, 2019 Author Share Posted August 15, 2019 (edited) Ah yes Lucky, seen one with hex nut instead of wing ...good work. Still don't know how to post stuff other than my text and my photos ( who just said just as well ? ) I remember seeing these with hex head yet not in a spot with limited access, but right in the middle of a 60s or 70s engine bay waiting to snag a sleeve I like to use the EA fuel injector band clamps on these coolant hoses, and did so again but thinking a socket would be better to access in place over a screwdriver bit for the Philips I do hate the common available vented? clamps that tend to cut into rubber hoses, especially smaller diameters Edited August 15, 2019 by Steptoe Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 15, 2019 Share Posted August 15, 2019 (edited) I bought some GEMI clamps when I replaced hoses on our Outback. They are german/european style I think and has raised 'threads', not 'perforated', as well as rolled edges, slightly narrower too. not cheap though. but, someone mentioned being able to snag some from european makes at the wrecking yard...? The T-bolt clamps that came with some mishimoto silicone hoses I put on my WRX were very nice. some of those come with springs to maintain force as hose material degrades/collapses w'ever Edited August 16, 2019 by 1 Lucky Texan 1 Quote Link to comment Share on other sites More sharing options...
DaveT Posted August 16, 2019 Share Posted August 16, 2019 Stainless and Aluminum don't get along well. Unless you use anti seize, if exposed to moisture, the corrosion that occurs expands and can clamp the bolts worse than rust. How long it takes depends on how wet and how long. 1 Quote Link to comment Share on other sites More sharing options...
Steptoe Posted August 16, 2019 Author Share Posted August 16, 2019 Yes, Lucky, many nicely engineered hose clamps go through the crusher and shredder. I have collected some different ones from time to time, yet seem to not be useful to me sizes. Narrow bands are useful. I often think the wide, perforated clamps are too wide I think the fastener world calls the clamps I hate - perforated. Probably for what they can do to the hose if too tight The genuine EA wire clamps do a great job yet can be fiddly to remove without damaging them. Some years back I had to buy a genuine hose from Nissan and it came with new wires clamps - they went into my hose clamp collection for later Dave, I will take your knowledge onboard and add it to their strength sometimes not what is expected .... Job is done and coolant now stays inside 2 Quote Link to comment Share on other sites More sharing options...
