sirtokesalot Posted August 15, 2019 Share Posted August 15, 2019 (edited) what stops it from working is it just the electrical or is there something that physically wont fit and work as well? Edited August 15, 2019 by sirtokesalot Link to comment Share on other sites More sharing options...
sirtokesalot Posted August 15, 2019 Author Share Posted August 15, 2019 i am quite serious here. i do have a complete doner car to pull any electrics from is it possible? Link to comment Share on other sites More sharing options...
FerGloyale Posted August 15, 2019 Share Posted August 15, 2019 (edited) It's electrical mostly. The wiring from the phase I mani, wont work with teh Phase II ECU. The phase II Manifolds won't fit the EJ22E. So, the way to do it is one of 2 ways. A) Full harness strip from the donor car, and install like doing an EJ swap in an older car. OR........... B ) Swap phase II wiring and throttle body over onto phase I intake. A block off plate will have to be made that fits between TB and intake, to block off the Idle passage. Injector connectors will need to be modded/swapped to work on the Phase I injectors. This will run fine, but will have CEL and won't have warm up idle control so you'll need to hold the gas on cold mornings for a 10~30 secs before will idle. * note, if you are installing into a Manual trans vehicle, you will not have a lower starter bolt......so that would need addressed. Edited August 15, 2019 by FerGloyale Link to comment Share on other sites More sharing options...
el_freddo Posted August 15, 2019 Share Posted August 15, 2019 And 3) swap your heads onto the EJ22. Cheers Bennie Link to comment Share on other sites More sharing options...
