nomaddanni Posted August 23, 2019 Share Posted August 23, 2019 Hi all, I’m hoping to get some insight on a rubbing noise coming from the RF area of my 2010 Outback Premium. I know basically nothing about cars, but what I can say is this: It started quiet and has gotten progressively louder over 2 months It sounds like a tire rubbing on plastic (but the tire is not rubbing anywhere) It gets noticeable from about 40mph up it gets louder if I’m taking a left turn, quieter to nonexistent if I’m taking a right turn It’s related wheel speed, not engine rpm My tire is cupping; I got an alignment and a rotation and the noise is still happening from the same vehicle location It does not sound like a hub going out because that did happen last year and I replaced all 4 hubs First mechanic was sure it was just out of alignment. It was, but the noise is still happening. Second mechanic who does not do tranny work suggested I take it to a shop that does. Any help is greatly appreciated. Link to comment Share on other sites More sharing options...
forester2002s Posted August 23, 2019 Share Posted August 23, 2019 When the noise is loud, what happens if you brake gently? ..Brake harder? Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 23, 2019 Share Posted August 23, 2019 were OEM hub assemblies installed? any recent work on that area of the car? maybe the brake dust shield is rubbing on the rotor? Link to comment Share on other sites More sharing options...
nomaddanni Posted August 23, 2019 Author Share Posted August 23, 2019 On 8/23/2019 at 3:41 PM, 1 Lucky Texan said: were OEM hub assemblies installed? any recent work on that area of the car? maybe the brake dust shield is rubbing on the rotor? Expand Yes the hubs were OEM and replaced about 9 months ago. Nothing but an oil change and a new battery installed since then. Link to comment Share on other sites More sharing options...
nomaddanni Posted August 23, 2019 Author Share Posted August 23, 2019 On 8/23/2019 at 3:35 PM, forester2002s said: When the noise is loud, what happens if you brake gently? ..Brake harder? Expand I haven’t noticed this impacting the sound so far. I will listen more carefully when I drive it later today and get back to you. Link to comment Share on other sites More sharing options...
FerGloyale Posted August 23, 2019 Share Posted August 23, 2019 Look at the plastic liner in the fender well. It may be cracked and blowing backward into the tire, on;y at higher speeds (over 40) 3 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 23, 2019 Share Posted August 23, 2019 ^^^^ good point FerG, I had something similar happen on a Toyota in the past. Link to comment Share on other sites More sharing options...
Rampage Posted August 23, 2019 Share Posted August 23, 2019 Yep, that happened on both our Legacy's. Yours look very similar. I replaced left and right on our 95. On our 97 it was just the right side, so I got out the heat gun and used a board to get it back into shape and added a few screws and washers to hold it. Link to comment Share on other sites More sharing options...
nomaddanni Posted August 25, 2019 Author Share Posted August 25, 2019 On 8/23/2019 at 5:57 PM, FerGloyale said: Look at the plastic liner in the fender well. It may be cracked and blowing backward into the tire, on;y at higher speeds (over 40) Expand So it’s not cracked but it is definitely missing whatever should be holding it in place. Could it seriously be something this simple?! Link to comment Share on other sites More sharing options...
FerGloyale Posted August 25, 2019 Share Posted August 25, 2019 On 8/25/2019 at 2:54 PM, nomaddanni said: So it’s not cracked but it is definitely missing whatever should be holding it in place. Could it seriously be something this simple?! Expand yup that's the issue. Link to comment Share on other sites More sharing options...
nomaddanni Posted August 25, 2019 Author Share Posted August 25, 2019 On 8/25/2019 at 4:48 PM, FerGloyale said: yup that's the issue. Expand So I’m at work and can’t do much else than tuck it back under where it belongs.. but the noise is still happening and when I check it’s not popped back out. Could it be vibrating somehow because it’s loose? I will try and secure it tonight and test drive it then. Link to comment Share on other sites More sharing options...
