sporta Posted July 5, 2004 Share Posted July 5, 2004 Hey all, Some time ago there was a link to a very good online service manual. DOes it still exist? and if so can somone post the link please....I need to replace my waterpump and that would be a great resource to have. Thanks Steve Link to comment Share on other sites More sharing options...
MilesFox Posted July 5, 2004 Share Posted July 5, 2004 i dont know if this is what you meant, but you said water pump. http://www.warpthree.com/milesfox/subaru/service/service.htm Link to comment Share on other sites More sharing options...
the_bard Posted July 5, 2004 Share Posted July 5, 2004 You were probably looking for http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797.HTML . They've since redone their webpage, and that link's gone :-\. Link to comment Share on other sites More sharing options...
Will Smith Posted July 5, 2004 Share Posted July 5, 2004 i have a few on my web site, you did not specify what model you have. Link to comment Share on other sites More sharing options...
sporta Posted July 5, 2004 Author Share Posted July 5, 2004 You were probably looking for http://www.cybrrpartspro.com/Chilton%20Manuals/8797m/8797.HTML . They've since redone their webpage, and that link's gone :-\. Yup that is the one i was thinking about. THanks miles and everyone else that responded. Should be a piece of cake (i hope) LOL Steve Link to comment Share on other sites More sharing options...
Partsman Posted July 5, 2004 Share Posted July 5, 2004 Try this guy's website - I printed off the EA-82 stuff and put it in a binder. It's the important pieces of an '89 FSM. Can't speak to the other links. http://finleyweb.net/default.asp?id=142 He has ultralight planes, so he only posted the parts that relate to the engine and engine management. Link to comment Share on other sites More sharing options...
Dianalee Posted July 7, 2004 Share Posted July 7, 2004 Yup that is the one i was thinking about. THanks miles and everyone else that responded. Should be a piece of cake (i hope) LOL Steve Good luck! I've been trying to accomplish the same thing on my 92 Loyale. So far I've broken two strap wrenches (one was supposedly designed for removing crank pulleys) and I still can't get my crank pulley off. Although I've gotten lots of advice from here, I can't seem to make it work. Dianalee Link to comment Share on other sites More sharing options...
calebz Posted July 7, 2004 Share Posted July 7, 2004 Good luck! I've been trying to accomplish the same thing on my 92 Loyale. So far I've broken two strap wrenches (one was supposedly designed for removing crank pulleys) and I still can't get my crank pulley off. Although I've gotten lots of advice from here, I can't seem to make it work. Dianalee Crank pulley. If its an auto, jam a big screwdriver in the flex plate and your good to go. If its a manual, you have a few options. 1- Brace rachet and long breaker bar against fender and bump the key(not recommended by me) 2- Get the tool from subaru $$ 3- Drill a hole in the top of the bellhousing and drop a screwdriver or something through it into the hole in the flywheel. (note, I don't suggest using a punch.. they break.. I have a crappy old phillips screwdriver that is the perfect size that I keep around just for this.) #3 is my preferred way of doing it. Thank you to moosens for the idea. Link to comment Share on other sites More sharing options...
sporta Posted July 7, 2004 Author Share Posted July 7, 2004 Crank pulley. If its an auto, jam a big screwdriver in the flex plate and your good to go. If its a manual, you have a few options. 1- Brace rachet and long breaker bar against fender and bump the key(not recommended by me) 2- Get the tool from subaru $$ 3- Drill a hole in the top of the bellhousing and drop a screwdriver or something through it into the hole in the flywheel. (note, I don't suggest using a punch.. they break.. I have a crappy old phillips screwdriver that is the perfect size that I keep around just for this.) #3 is my preferred way of doing it. Thank you to moosens for the idea. On my 88 DL with the auto trans, i just pulled the black rubber boot on the flywheel and cranked the motor by hand till i got to the notch and jammed a good screwdriver (flathead) in and the pulley came off really easy. Thanks again to all who responded to me the repair went really rather smothe was just diffucult cause i had never done that before on a subby Steve Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 7, 2004 Share Posted July 7, 2004 Pull a plug, and fill the cylinder with nylon rope - make sure it's on the compressions stroke. Remove bolt. Remove rope. GD Link to comment Share on other sites More sharing options...
Dianalee Posted July 7, 2004 Share Posted July 7, 2004 Crank pulley. If its an auto, jam a big screwdriver in the flex plate and your good to go. If its a manual, you have a few options. 1- Brace rachet and long breaker bar against fender and bump the key(not recommended by me) 2- Get the tool from subaru $$ 3- Drill a hole in the top of the bellhousing and drop a screwdriver or something through it into the hole in the flywheel. (note, I don't suggest using a punch.. they break.. I have a crappy old phillips screwdriver that is the perfect size that I keep around just for this.) #3 is my preferred way of doing it. Thank you to moosens for the idea. What is "the tool" (as in how does is work and would I really have better luck with it) and how much does it cost? I'm going to have to do this again (replace the timing belt) in 60,000 miles, right? That's about a year for me and I would like it to be easier next time or I will find myself putting it off. I did try jamming a screwdriver in the flexplate and now my timing window is bigger. I'm thinking of putting a curtain over it and plants in front. Dianalee Link to comment Share on other sites More sharing options...
