glf subie Posted August 27, 2019 Share Posted August 27, 2019 I need to replace my fuel pump control unit, with 6 pins. I am having a difficult time locating this part. Does anyone know how to find one? Link to comment Share on other sites More sharing options...
Steptoe Posted August 29, 2019 Share Posted August 29, 2019 I have seen figures of mid two hundred dollars if still available new Many seem to find used for replacement I threw one out! What can be wired in is an electrical safety cut out unit as used for same purpose in propane fuelled conversions, only to shut off a relay for gas pressure safety solenoid. They are mostly four wires Earth IGN Coil signal , forget if pos or neg, think neg Wire out carries 12v pos to power up pump or pump relay Link to comment Share on other sites More sharing options...
el_freddo Posted August 29, 2019 Share Posted August 29, 2019 Over here an ‘82 won’t have that fuel pump cut relay module thingy. You sure yours has one? Cheers Bennie Link to comment Share on other sites More sharing options...
old sub freak Posted August 29, 2019 Share Posted August 29, 2019 I have the same problem. on my hatchback ..I have been told to just by pass it but .... I too would rather fix it "The right way" haha I may try and chase down a used one Link to comment Share on other sites More sharing options...
el_freddo Posted August 30, 2019 Share Posted August 30, 2019 As recent as two days ago I was talking to a mate about how to rig one up. Have a closed relay intercept the fuel pump power wire. The trigger wires are ignition and the earth - from the oil pressure light. The idea is that when you don’t have oil pressure the fuel pump turns off. You could use the alternator warning light too. Yes you loose the priming function but this could easily be negated with a momentary switch to bypass the oil pressure light trigger. Push this button for several seconds and you’re primed ready to go Cheers Bennie Link to comment Share on other sites More sharing options...
Steptoe Posted August 30, 2019 Share Posted August 30, 2019 Triumph had a roll over protection device as well as oil pressure switch ignition cut out Link to comment Share on other sites More sharing options...
glf subie Posted August 31, 2019 Author Share Posted August 31, 2019 Thank you Steptoe and el_freddo, I will look into those options as I can not find a replacement. Cheers Link to comment Share on other sites More sharing options...
