bullseye451 Posted August 28, 2019 Share Posted August 28, 2019 Hi guys it’s been awhile since I’ve been on here. i just purchased a 2007 Outback 2.5l its not allowing fuel in the tank at normal speed. Any ideas what I may need to troubleshoot or replace. Thanks Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted August 28, 2019 Share Posted August 28, 2019 probably a clogged evap 'drain' hose or malfunctioning/stuck evap valve. Try a search for the problem there are several threads about the issue. Locate the charcoal canister and try fueling with various hoses disconnected, you might locate the area of the problem that way. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted August 28, 2019 Share Posted August 28, 2019 (edited) Spiders or mud wasps nest in the charcoal canister vent line/fitting into the frame rail. Or an exploded charcoal canister. Or a failed vent valve. GD Edited August 28, 2019 by GeneralDisorder 1 Link to comment Share on other sites More sharing options...
FerGloyale Posted August 29, 2019 Share Posted August 29, 2019 Had this happen to 3 cars now. 1 98 forester, and 2, 03 Outbacks. all 3 were fixed by replacing the charcoal canister. Not sure if it was the canister, the valve, or what but simply replacing the unit solved it. Link to comment Share on other sites More sharing options...
bullseye451 Posted September 13, 2019 Author Share Posted September 13, 2019 Thanks guys I replaced the charcoal canister but haven't had a chance to test it out yet. I found a donor car for it. Now i just need to fix all the other bugs! air bag light and alarm heated seats don't work check engine light dim passenger headlight sticking front calipers (machine rotors rust pitting) passenger door power window motor replace the driver side passengers door (dented from accident) The car sat for 3 years and has several issues I'm sure there is more that i haven't found yet. Link to comment Share on other sites More sharing options...
bullseye451 Posted September 13, 2019 Author Share Posted September 13, 2019 On 8/28/2019 at 12:44 PM, 1 Lucky Texan said: probably a clogged evap 'drain' hose or malfunctioning/stuck evap valve. Try a search for the problem there are several threads about the issue. Locate the charcoal canister and try fueling with various hoses disconnected, you might locate the area of the problem that way. i replaced the whole charcoal canister and if that didn't fix it ill try your suggestion. thanks! Link to comment Share on other sites More sharing options...
