Steptoe Posted September 2, 2019 Share Posted September 2, 2019 OK Whoever has done the full 'just EJ it's to an EA81 body BRAT, Brumby, wagon or sedan Maybe not the hatch coz think it was shorter wheelbase My first hands on looked like 50-52 mm should be removed Now, made up a support to prop up the tailshaft as it comes out of the AWD box Recap, if is an EJ20 and AWD 5MT out of GF8 Impreza of 99 EJ sits in the engine bay with gearbox bolted in place, gear lever shortened 60 mm, stay rod yet to be mounted to floor Using an EA82 brace that used the automatic crossmember mounting bolts in EA82 in the EA81, spaced off floor about 14 mm, and AWD. just resting here Now it looks like 35-40 mm is needed to be removed Planning to grind off the lump of weld at rear yoke to see if I can pull tube off yoke, cut then weld up again The uni is a little arthritic so if I stuff up boreal harm done Link to comment Share on other sites More sharing options...
el_freddo Posted September 2, 2019 Share Posted September 2, 2019 Hey Jono, the wagon wheelbase is 100mm shorter than the brumby from memory, and it shares the same wheel base as the hatch IIRC. Someone will have some specs hidden away somewhere. Hopefully they’ll share. As for the cutting and welding, you’re correct - cut the weld carefully and that will “release” the tube of the tail shaft from the rear yoke flange arrangement. Mark where you want to cut the shaft and very carefully cut it ensuring you’re cutting it square. Then when welding it, ensure the tailshaft and yoke flange are parallel to each other and go for it in sections at a time. It’s a good idea to check that it rotates without any wobble in it before using it in the car. We did this on a ‘78 Chrysler Lancer. Rear of the shaft isthr place for these mods - just in case the weld ever breaks you won’t be flipping the car with you in it Cheers Bennie Link to comment Share on other sites More sharing options...
STi 22B Posted September 2, 2019 Share Posted September 2, 2019 Cogs working overtime in empty space.... If you are using 2 piece propulsion shaft and making a centre bearing mount, then mix and match EJ auto and EA82 shafts. 99% sure this is what was used in Toonga's Brumby when we fitted the AWD EJ 5spd box behind his carburettorred EJ20 SOHC setup. Link to comment Share on other sites More sharing options...
Steptoe Posted September 2, 2019 Author Share Posted September 2, 2019 Well got the hatch @ 2380 , 80 mm shorter than sedan sedan & hardtop @ 2460, 80 mm longer than hatch Wagons DL (2WD)? 2455mm and 4WD 2445mm Brumby spec not in this manual so pulling it from Australian MV supplement booklet...2445mm So same Brumby and 4WD EA81 wagon Give that memory a gentle tap Bennie And Mr22B, was thinking of this, just trying not to waste cyberspace .Must hit FB see if Toonga recalls Thinking centre bearing support mounts remains same so front shaft length is what changes and then suggestion is mix EA and EJ stuff too Won't hurt me making up a dummy shaft out of useless parts. A mate when he needs my help is a welder with an invoice book when indeed help has nice saw and welding stuff Link to comment Share on other sites More sharing options...
STi 22B Posted September 3, 2019 Share Posted September 3, 2019 Yep, centre bearing stays in the same spot for the same year/models but changes for different EA and EJ models and because you do not already have a mounting spot for the centre bearing, then you just need to make up the correct length and then add the centre bearing mount afterwards Link to comment Share on other sites More sharing options...
FerGloyale Posted September 5, 2019 Share Posted September 5, 2019 On 9/2/2019 at 3:55 PM, Steptoe said: Well got the hatch @ 2380 , 80 mm shorter than sedan sedan & hardtop @ 2460, 80 mm longer than hatch Wagons DL (2WD)? 2455mm and 4WD 2445mm Brumby spec not in this manual so pulling it from Australian MV supplement booklet...2445mm So same Brumby and 4WD EA81 wagon Give that memory a gentle tap Bennie And Mr22B, was thinking of this, just trying not to waste cyberspace .Must hit FB see if Toonga recalls Thinking centre bearing support mounts remains same so front shaft length is what changes and then suggestion is mix EA and EJ stuff too Won't hurt me making up a dummy shaft out of useless parts. A mate when he needs my help is a welder with an invoice book when indeed help has nice saw and welding stuff So I'm gonna dig a little deeper in examining wheelbase as it relates to drivelines. (Props) There are only two lengths of wheelbase in relation to the length of the prop, body datum point lengths, suspension mount points, etc. the actual listed length varies by 15~20 mm when you get into different weight/trim/fwd/4wd option, because the rear trailing arm torsion setup makes the wheel travel fore/aft in it swing, so depending on height, the length between front/rear wheel centerlines changes. Hatch is anywhere from 2370~2380, and wagon/sedan/hardtop/Brat/Brumby are all 2445/2460 With the lower riding models being the latter in each set. So when evaluating prop lengths, just think Short vs. long body wheelbase. FSM lists length of the 2 props at 1057mm and 1136mm respectively. Measured as "distance between joints" 1 Link to comment Share on other sites More sharing options...
Steptoe Posted September 5, 2019 Author Share Posted September 5, 2019 Thanks for that input Got some inside info from a fella who had a Brumby with an EJ and AWD EJ box Mr Sti22B knew it well L Series gearbox end of tailshaft and K Series centre bearing EJ rear diff end of tailshaft And an EJ rear diffs flange on the EA82 rear diff to mate the differing bolt patterns Only found this after hopping out 35 mm if EJ rear end tailshafts didn't I ? The Impreza tailshafts tube thickness is just 1.6 mm ! Link to comment Share on other sites More sharing options...
alexbuoy Posted September 5, 2019 Share Posted September 5, 2019 I posted in the other thread i’m sure you saw. Another option is GC automatic driveshaft. My friend used it and he says : The driveshaft is maybe an inch shorter than what would be ideal, but the splines on the slip yoke still have 2-3” of engagement, and the dust cover still overlaps over the seal on the tailhousing. Link to comment Share on other sites More sharing options...
Steptoe Posted September 5, 2019 Author Share Posted September 5, 2019 Noted. GC auto thanks. Now, not really EJ conversant, I know GC8 the sedan 93- 2000? And GF8 as wagon same era. No idea the letters assigned after gc and gf8 Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 5, 2019 Share Posted September 5, 2019 You can use an 93-07 (gc/gm/gf/gd/gg) 4eat driveshaft, they're all virtually the same length. You may have to change the pinion flange to match the driveshaft depending on what rear diff you use. Link to comment Share on other sites More sharing options...
Steptoe Posted September 6, 2019 Author Share Posted September 6, 2019 (edited) That's the sort of detail I needed to hear , thanks 86Bratman funny , down under a driveshaft is usually a front axle CV shaft, and your driveshaft is our tailshafts. Rear axles are rear axles Edited September 6, 2019 by Steptoe Link to comment Share on other sites More sharing options...
carfreak85 Posted September 6, 2019 Share Posted September 6, 2019 20 hours ago, alexbuoy said: I posted in the other thread i’m sure you saw. Another option is GC automatic driveshaft. My friend used it and he says : The driveshaft is maybe an inch shorter than what would be ideal, but the splines on the slip yoke still have 2-3” of engagement, and the dust cover still overlaps over the seal on the tailhousing. That sounds like a terrible idea, especially anywhere it rains, snows or where they salt the roads. Link to comment Share on other sites More sharing options...
Steptoe Posted September 10, 2019 Author Share Posted September 10, 2019 Well, an update First in place measures looked like 50-52 mm needed to be cut out of the 99 Impreza manual tailshaft. Leveled up the gearbox, propped up at centre bearing within 6 mm off a likely floor mount support and the cut looked closer to 35 to 40 mm. So using measure twice cut once ( thankyou Mr Harrison , woodwork 1980) I cut it at 35, cleaned up the end plug, uni and whacked it back in - bit like a press fit no one ever mentions! so hard a whack it loosened up the stuff joint! That cut now looks like it should have been just 20 mm if the tailshaft or 15 for tight fit ! Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 11, 2019 Share Posted September 11, 2019 (edited) That's why I specifically used the 4eat impreza shaft. It's about 50mm shorter than the manual version. Edited September 11, 2019 by 86BRATMAN Link to comment Share on other sites More sharing options...
el_freddo Posted September 11, 2019 Share Posted September 11, 2019 10 hours ago, 86BRATMAN said: That's why I specifically used the 4eat impreza shaft. It's about 50mm shorter than the manual version. It MUST be the impreza unit, not the liberty/legacy auto unit? Cheers Bennie Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 11, 2019 Share Posted September 11, 2019 Correct, the legacy/liberty driveshaft/tailshaft is a minimum of 5"/127mm longer than the impreza due to the difference in wheelbase. 1 Link to comment Share on other sites More sharing options...
Steptoe Posted September 12, 2019 Author Share Posted September 12, 2019 Wonder if Forester tailshafts same or different to Imps And Libacys? Link to comment Share on other sites More sharing options...
el_freddo Posted September 12, 2019 Share Posted September 12, 2019 1 hour ago, Steptoe said: Wonder if Forester tailshafts same or different to Imps And Libacys? Same platform so they should be the same unless the lift is built into the centre bearing mount. Cheers Bennie Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 13, 2019 Share Posted September 13, 2019 The carrier bearing is indeed different on the forester, the suspension lift is countered by a drivetrain drop or roughly one inch (25mm). Most models they can be changed out with for non lifted version, I can't say for sure on those though. Link to comment Share on other sites More sharing options...
Steptoe Posted September 13, 2019 Author Share Posted September 13, 2019 Ok My donor GF8, 1999 wagon and it's sedan sister have wheelbase of 2520 The foz of same year is wheelbase of 2525 Liberty sedan 2630 Outback 2650 Link to comment Share on other sites More sharing options...
