metalfanmartin Posted September 10, 2019 Share Posted September 10, 2019 (edited) 2010 2.5L outback, petrol. 143,000k's. Wife called me yesterday, car wouldn't start (not turning over at all). Called roadside assistance, they deemed a crapped out battery. When I got home from work I replaced the battery with a brand new one, it was a bit larger CCA wise. Tried turning car on, it turned over but wouldn't fire. I pulled keys out, and then tried again. Car turned on fine. But a few error messages remain on the dash, picture included. I checked output of alternator, 14.5v. Seat belt and handbrake light do extinguish normally But not whatever the P with the crossout is? Any ideas what I should do? Leave it for a while and see if they'll clear themselves? Cheers Edited September 10, 2019 by metalfanmartin typos/extra info Link to comment Share on other sites More sharing options...
brus brother Posted September 10, 2019 Share Posted September 10, 2019 parking brake engaged? Link to comment Share on other sites More sharing options...
metalfanmartin Posted September 10, 2019 Author Share Posted September 10, 2019 40 minutes ago, brus brother said: parking brake engaged? Sorry, what? The yellow/orange P crossed out stays illuminated, the ABS stays illuminated, and the anti-skid light stays illuminated when the car is running. As far as I can tell the car is operating normally besides these. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 10, 2019 Share Posted September 10, 2019 Low voltage codes. They will likely clear on their own after a few drive cycles. The initial crank but no start is normal for all the 04+ DBW cars. You have to power on the ECU then wait about 15 seconds for it to initialize. GD 3 1 Link to comment Share on other sites More sharing options...
Mike104 Posted September 10, 2019 Share Posted September 10, 2019 44 minutes ago, GeneralDisorder said: The initial crank but no start is normal for all the 04+ DBW cars. You have to power on the ECU then wait about 15 seconds for it to initialize. GD Good to know. Link to comment Share on other sites More sharing options...
metalfanmartin Posted September 16, 2019 Author Share Posted September 16, 2019 On 9/10/2019 at 2:41 PM, GeneralDisorder said: Low voltage codes. They will likely clear on their own after a few drive cycles. The initial crank but no start is normal for all the 04+ DBW cars. You have to power on the ECU then wait about 15 seconds for it to initialize. GD Thanks for the reply mate. Still showing the error codes I've even tried plugging an OBDII thing in and clearing the codes, it didn't appear to do anything. Doesn't even show the codes on the OBDII? I must be doing something wrong lol. Link to comment Share on other sites More sharing options...
CNY_Dave Posted September 18, 2019 Share Posted September 18, 2019 Is 2010 new enough to be one of the ones where all hell breaks loose when you change the battery or jump start it? 1 Link to comment Share on other sites More sharing options...
metalfanmartin Posted September 18, 2019 Author Share Posted September 18, 2019 2 hours ago, CNY_Dave said: Is 2010 new enough to be one of the ones where all hell breaks loose when you change the battery or jump start it? It would appear so! It's due for a 12m service, I wonder if I should just ask the mechanic to clear the codes, or whether they're gonna try and charge me heaps for it Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 18, 2019 Share Posted September 18, 2019 (edited) Have the codes cleared with a pro tool. GD Edited September 18, 2019 by GeneralDisorder Link to comment Share on other sites More sharing options...
