subaru420 Posted July 5, 2004 Share Posted July 5, 2004 Mine backfires pretty consistently when shifting from first and second. as well as when using the engine to slow. is that common? I am less than stoked about it... chicks dont dig sputtery exhaust noise. what can I do to remedy this??? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 5, 2004 Share Posted July 5, 2004 Leak in your exhaust system. Try putting some quarters in the Air Suction Valve supply pipes - where they screw into the valves. GD Link to comment Share on other sites More sharing options...
Will Smith Posted July 5, 2004 Share Posted July 5, 2004 couild be a bad distibutor cap or wires. to check the wires, open the hood when it is dark and if you see a light show around the wires time to change. Link to comment Share on other sites More sharing options...
subieman Posted July 5, 2004 Share Posted July 5, 2004 I have numerous exhaust leaks on my ea81 and she backfires pretty bad too. So until I save enough money to have the exhaust system replaced I disconnected the air suction valve. It helps with the really loud bangs! I did not use the quarter trick, I just disconnected the pipe where it connects to the air filter housing and plugged it up. Link to comment Share on other sites More sharing options...
subynut Posted July 5, 2004 Share Posted July 5, 2004 Yup, I vote for a leaky exhaust system too. Going to finish my exhaust today. Ya know what's fun: as I'm coming up on a pedestrian, I'll sit on the throttle where it doesn't make too much noise and when I'm right next to them, I jab the throttle and watch them jump 3 feet in the air! Link to comment Share on other sites More sharing options...
northguy Posted July 5, 2004 Share Posted July 5, 2004 Let me see - with a name like 420, maybe you crossed a wire or two? - but it's probably an exhaust leak. Link to comment Share on other sites More sharing options...
WoodsWagon Posted July 6, 2004 Share Posted July 6, 2004 Yup, thats exhaust leaks. My EA82 GL had a header that was rusting out, as well as the rest of the pipes, and I removed everthing from the cat back (now thats a preformance exhaust!) and it would throw flames out the back of the cat when you let off on the gas. i guess its too much oxygen entering the catilitic converter that causes the backfiring. Link to comment Share on other sites More sharing options...
seattlelegacy Posted March 15, 2006 Share Posted March 15, 2006 Where is this Air Suction Valve on an EA81???? Link to comment Share on other sites More sharing options...
Skip Posted March 15, 2006 Share Posted March 15, 2006 I tried the "search" feature, ya ought to try it sometime, works real well, found you this has a picture of one and some good info air suction valve Link to comment Share on other sites More sharing options...
seattlelegacy Posted March 16, 2006 Share Posted March 16, 2006 I tried the search function too (I feel so grown up!) You must mean this picture: Link to comment Share on other sites More sharing options...
Skip Posted March 16, 2006 Share Posted March 16, 2006 sorry you missed it this is what I refered to Link to comment Share on other sites More sharing options...
seattlelegacy Posted March 16, 2006 Share Posted March 16, 2006 Skip said: sorry you missed itthis is what I refered to That's actually great news. I have been wondering what that stupid thing is and does... I learn something new every day. Jordan Link to comment Share on other sites More sharing options...
Uberoo Posted March 16, 2006 Share Posted March 16, 2006 can you remove the air suction valve with no ill effects? I dont like driving a CARBED four pot and you can't find engine because of maze of vacuum lines(exagerated) why would any one in their right mind want to get rid of backfiring? I cut the exhaust off after the first muffler and I intentially make it backfire/pop/rumble... Link to comment Share on other sites More sharing options...
Skip Posted March 16, 2006 Share Posted March 16, 2006 Jordon, you are welcome glad it helped somewhat Link to comment Share on other sites More sharing options...
