aselby Posted September 25, 2019 Share Posted September 25, 2019 For starters I’ll say I did search and didn’t find any definitive answers, I found similar questions and the only answers were go search. Back story: I have a 2004 Saab 92-x turbo with a bad engine (I will call it a wrx from now on). I plan on putting an engine in the car for a few months and then transplanting it into my 1966 vw bug. The Saab will just be used to dial in the car and make sure it runs good. I have an ej255 short block and I want to put sohc heads in it and run it with the stock wrx harness and pcm. Ideally I’d like to use 251 heads because I have a rebuilt set. I know the heads will physically fit and the turbo will have some clearance issues that can be worked out. I know I will need to plumb oil and coolant to the turbo. What I’m not sure about is ignition coils and camshaft gears. The wrx uses Coil on plugs and the 251/253 heads use conventional wires. Does subaru make a coil on plug coil from a later model sohc engine that I can fit on a 251 head and be compatible with the wrx harness? I can tig a bung to bolt down the coil if needed. Will the camshaft sensor read the sohc cam gear properly? Also if anyone has done a similar conversion I’d love some feedback. Link to comment Share on other sites More sharing options...
FerGloyale Posted September 25, 2019 Share Posted September 25, 2019 Won't run on stock management. IIRC, Cam sensors are all different setup. Turbo EJ255 is AVCS, with sensors at the back of each intake Cam, not on the gear like EJ251/3 setup. And also the EJ255 intake won't bolt onto the SOHC heads. Maybe with an adpater/spacer? Or you could try to swap wiring over to a 251/3 manifold? The DOHC heads really aren't much larger, especially width wise........Why not just run a full EJ255 rather than some hybrid? Link to comment Share on other sites More sharing options...
aselby Posted September 25, 2019 Author Share Posted September 25, 2019 (edited) The short block is a 255, the heads would be 251, the pcm harness and manifold are stock 205 from an 05 wrx. No avcs to deal with. The dohc in my bug means extensive body modifications. Do you know of the cam gears will work or a cop that will fit? Edited September 25, 2019 by aselby Link to comment Share on other sites More sharing options...
Numbchux Posted September 26, 2019 Share Posted September 26, 2019 The crucial question (which I do not know the answer to), is whether the EJ205 ECU can read the EJ251 cam sensor. If you have them, take a look at that sprocket and compare the tone wheels. The spark plug tubes in the later EJ253s (which had COP) are deeper than the older 251/253s. So no, those coils are not a direct fit. But the extra length on the boot could probably be dealt with with some sort of spacer/adapter/mounting bracket. Link to comment Share on other sites More sharing options...
carfreak85 Posted September 26, 2019 Share Posted September 26, 2019 You can buy shorter boots from NGK and swap them, I did that for the COP conversion on my EJ20G. Link to comment Share on other sites More sharing options...
Numbchux Posted September 26, 2019 Share Posted September 26, 2019 As I think about it, I might have it backwards. I think we were trying to use COP heads on a non-COP car, and the tubes on the COP heads were shorter, as the regular plug wires didn't reach the plugs, and the older valve covers didn't seal on the newer tubes (I don't remember what was different that required the use of the older valve covers...). So unless you can find a longer boot for the stock plugs. But since the valve covers are different, you'll probably be making custom mounts anyway, so a different coil might be a better option anyway. The Audi R8 Coils (used on many other things, but that's the easy way to look them up) are powerful and reasonably priced, I see those being used a lot on 1UZ COP conversions. Otherwise it might make more sense to use 4 standalone coils (Chevy LS style), with a short plug wire. Lots of options. Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 26, 2019 Share Posted September 26, 2019 (edited) You'll need to use the 05+ sohc ej25 cam and crank timing gears to get the correct pattern, the 205 intake manifold will bolt to phase 2 sohc heads. You may be better off going with GM LS coil near plug setup and doing custom wires. You'd need to adjust the ignition dwell settings in the 205 ecu to keep from frying coils though. Edited September 26, 2019 by 86BRATMAN 1 Link to comment Share on other sites More sharing options...
aselby Posted September 26, 2019 Author Share Posted September 26, 2019 Great information thank you. You mentioned the camshaft and crankshaft gears need to be from a 05+ sohc engine. Do you know if the crankshaft sprocket from the stock wrx engine is the same. I’d like to keep the coil on plug if possible. Does anyone have a listing of the different lengths of boots that will fit on the coils? Thanks again for all the help 1 Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 26, 2019 Share Posted September 26, 2019 The wrx crank gear is the same. You'll most likely have to fab up a mount for the coil and then see how long the boot needs to be. The 2010-2012 ej25 uses COP, the boots from them may be compatible with the wrx coils. 1 Link to comment Share on other sites More sharing options...
Micah Posted April 15, 2020 Share Posted April 15, 2020 Aselby, we should talk. I’ve worked out some details for my SOHC conversion on my 03 WRX, and I’d like to share info with you and hopefully get some from you. Cheers- Link to comment Share on other sites More sharing options...
aselby Posted April 19, 2020 Author Share Posted April 19, 2020 Micah, I just got the engine fired up for the first time last night. If you have any questions feel free to reach out to me. 1 Link to comment Share on other sites More sharing options...
Micah Posted April 24, 2020 Share Posted April 24, 2020 No kidding?! Tell me what you did... I measured and measured and I think I can use an ej222 cam gear (same as ej251 from later Legacy) and 2010 Outback coils-on-plug, with custom brackets. I think we may be in a very exclusive club... Where are you? I’m in Albuquerque Link to comment Share on other sites More sharing options...
aselby Posted May 2, 2020 Author Share Posted May 2, 2020 You will need a 05+ cam gear for the drivers side cam gear to get the correct pattern. The coils from a 10+ outback will work but you need to switch the wiring orientation in the plugs. You don’t need brackets just a bolt to secure them. I had to space the turbo up 10mm to get everything to fit. 2 Link to comment Share on other sites More sharing options...
Micah Posted May 3, 2020 Share Posted May 3, 2020 That’s awesome. Looks like you’ve got 10mm phenolic spacers too; they keep the manifold at roughly the same plane... Good to know about bumping up the turbo- that’s easy. Thank you. Let me know how it runs! Link to comment Share on other sites More sharing options...
el_freddo Posted July 31, 2020 Share Posted July 31, 2020 Any update on how this thing runs? It could be the solution I’m looking for to avoid emissions testing with what I want to do in turboing my brumby. Cheers Bennie Link to comment Share on other sites More sharing options...
el_freddo Posted December 7, 2023 Share Posted December 7, 2023 Ok since there’s been zero contact or update from Micah or aselby I went ahead and applied their build application/idea to an EJ205 setup. I’m not done yet as I’ve got an NA EJ202 block and matching heads as the test mule running all the turbo gear from a 2002 SF GT forester - which I’m not sure if this model was sold in the US. It’s basically the GD WRX setup but with a TF035 turbo. I’ve got it running which is a great feeling but I also have a misfire on cylinder 1 and a check engine light I can’t read (I need to splice in the diagnostics plug as I got a bit trigger happy with the wire cutters). On cylinder 1!I’ve checked the coil pack, swapped for a good running one on another cylinder, same for the spark plug but the issue remains with cylinder 1. Wiring continuity for the coil pack and injector checks out from either unit to the ECU. Valve clearances are good/on point. Compression on each cylinder, engine cold is: Cyl 1 = 185psi Cyl 2 = 200psi Cyl 3 = 210psi Cyl 4 = 205psi It seems the HG issue is on cylinder 1 but that compression doesn’t seem poor enough to induce a misfiring cylinder to the point that disconnecting the coil’s trigger doesn’t change the engine’s behaviour at all What I haven’t done is swapped the injector to another cylinder to see if the issue moves with the injector, that’s next to do. I can hear the injector clicking using a piece of dowel held against it when the engine is running. Disconnecting the coil plug doesn’t change the idle at all, or how it revs. Does anyone have any insights as to what the issue might be? I’ve cut down the loom with the only things not hooked up are the temp sensor for the deleted up pipe cat, the neutral switch and those random wires that go to dash switches such as the rear demister etc. I don’t have the fuel temp sensor in the fuel tank hooked up but haven’t heard of this being an issue before. This wiring loom and ECU combo ran fine with the complete DOHC EJ205 still in the Forester before it was pulled out and I started playing with it all. Cheers Bennie Link to comment Share on other sites More sharing options...
el_freddo Posted December 10, 2023 Share Posted December 10, 2023 (edited) Ok finally nutted this one out. Had the wiring extension on my cam angle sensor the wrong way around. Idles minty smooth and sounds real meaty when revving it now! Cheers Bennie Edited December 10, 2023 by el_freddo Link to comment Share on other sites More sharing options...
