2011 Legacy Sedan Drivers door window
haven’t seen newer motors/tracks yet, just bad switches.
Not on any 2010+ Subaru windows, but on a couple models with limited space, or wrecked ones, I’ve swapped color matched doors.
Around here roughly around 10-15 years old seems a sweet spot of finding a low price, no rust, and non-faded paint so a door swap sometimes is a good fit.
2010 - 2014 is the interchange range.
If you can't roll the window down, it's hard to get to the FWD window to regulator bolt.
The car I pulled it from the door was trash anyway so I cut the interior metal to get at the bolt.  Easy R&R.
  • Thanks 1
I pulled the old on apart to see how it was put together.  Motor and cable spool are all one unit.  Since it was junk, I pulled it apart.  Yes, while it's possible you'd never change just one part of the regulator.  Just buy the complete assembly.  It's over $800 from Subaru but under $50 a you pull yards.  2010 - 2014 is the interchange range.  Outback, Legacy, for sure.
  • Like 1
