markjs_pnw Posted October 21, 2019 Share Posted October 21, 2019 These EA81s must be low friction. I never even overheated. Got close to the red but each time the thermo would open and it coooled off. I noticed because the heater stopped working. Anyway, engine is fine, but now I definitely need a radiator. I'm nervous about wrecking yards, do they check for stop leak? In any case it lists locally (the cheapest) for $270 and $125 out of town at Autozone. I'm of limited funds, so the so called "grade A" junkyard part for $50 seems a lot more affordable. Is it worth the risk? Also, what all year and models have radiators that will fit? IIRC the EA82s were bigger and were part plastic (which I don't want)? Link to comment Share on other sites More sharing options...
el_freddo Posted October 22, 2019 Share Posted October 22, 2019 Stick with anything EA81 and it’ll fit. As for junkyard item vs chain store vs quality radiator builder, I’d go the builder if possible. You might be surprised with the cost they could build a radiator for. They usually need your old one as a template if the vehicle is not staying with them. Cheers Bennie Link to comment Share on other sites More sharing options...
markjs_pnw Posted October 22, 2019 Author Share Posted October 22, 2019 Well I ordered the junkyard part for now. I did make an inquiry about having one built for it. I bet it's not the first request for this they've had. Link to comment Share on other sites More sharing options...
silverhelme Posted October 23, 2019 Share Posted October 23, 2019 Flush it well and pressure test it if you can. Stop leak should not be a problem in the radiator with a good flush. Link to comment Share on other sites More sharing options...
idosubaru Posted October 23, 2019 Share Posted October 23, 2019 (edited) Have you checked eBay and rock auto? Edited October 23, 2019 by idosubaru Link to comment Share on other sites More sharing options...
Subarule Posted October 24, 2019 Share Posted October 24, 2019 This is a ways from you but still in WA state. Check out this place, their expertise is rebuilding radiators: https://hartradiator.com/ Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted October 24, 2019 Share Posted October 24, 2019 Hey Mark, 1-800 radiator might be able to hook you up if the junkyard piece doesn't work for you. Also, I have been looking into potential replacement radiators from other models of cars. I'll share my findings with you as soon as I have something concrete. Twitch Link to comment Share on other sites More sharing options...
markjs_pnw Posted October 24, 2019 Author Share Posted October 24, 2019 Well new, nobody beats Autozone at $125 Though could be core charge unincluded makes rock auto $200? I guess I should go new ut it's a huge hit. Link to comment Share on other sites More sharing options...
