H6 Timing cover area oil leak
I have a 2006 B9 Tribecca with a 3.0 H6 engine with 190K.  It recently started a rather severe oil leak.  Drips about once per second.  The drips are mostly dripping from the timing cover right in front of the oil pan.  The oil is not coming from either of those two gaskets though.  Is it coming from somewhere in between and above those two.  Can't see where the exact source is.  Its dripping from the bottom of the timing cover because it is the low point.
Any input or ideas on where the source is would be greatly appreciated.
  • 2 weeks later...
the other half has an 06 LL Bean Outback with the H6 and oil leaks.. his is definitely coming from the oil cooler and apparently this is pretty common on these engines.
I would suggest cleaning things up as much as possible, run it for a bit and try to determine exactly where the oil is coming from.
  • Like 2
