Tajsix Posted November 2, 2019 Share Posted November 2, 2019 2011 Subaru legacy 2.5 limited code p0500 present with a flashing Cruise light and a flashing red break light and check engine light fot the p0500 code. the traction icon and the abs light are on also. looking for info on how to fix. Thanks Quote Link to comment Share on other sites More sharing options...
rverdoold Posted November 2, 2019 Share Posted November 2, 2019 It is the front speed sensor giving an error. There is a speed sensor mounted on the front housing of the gearbox assuming it is an automatic. It could be as simple as a disconnected cable to a bad sensor. Try to reset the ecu and see how fast it comes back. Quote Link to comment Share on other sites More sharing options...
Tajsix Posted November 3, 2019 Author Share Posted November 3, 2019 Sorry I should have mentioned it is a automatic tranny. I did clear the code and it comes back on as soon as you start driving again. Is there another name for the sensor? Or is it called a speed sensor? Can it be checked for resistance or how would you check it? Thanks for the info. Steve Quote Link to comment Share on other sites More sharing options...
rverdoold Posted November 3, 2019 Share Posted November 3, 2019 Further I assume it is a cvt rather than a 4EAT (4 speed). But in case of the 4eat it is quite hard to reach as it is on the upper left side of the transmission case. You could disconnect the transmission harness and reconnect or even spray the connector with wd40. Quote Link to comment Share on other sites More sharing options...
Tajsix Posted November 4, 2019 Author Share Posted November 4, 2019 I pulled the followingABS codes today with a different scanner C0057 ABS/VDC-anti-lock brake System/Vehicle Dynamic Control, C0234 EPB-Electronic Parking Brake, C0231 EPB, C0028 Rear Left ABS Sensor Signal, C0024 Front Left ABS Sensor Signal and C0057 ECM Control System I will check for the speed sensor and get back with you Thanks Quote Link to comment Share on other sites More sharing options...
rverdoold Posted November 8, 2019 Share Posted November 8, 2019 So basically the abs system is messed up by missing info because: The front speed sensor knows the axle rotation to the or in the front diff, so actually the front axles. Now, normally both front axles spin at equal speed, measured by the abs tone ring in the wheel hub (abs speed sensor). When you take a turn the left and right side axles will rotate at different speed but that is know by the steering angle sensor mounted to the power steering module. So: VDC comes in place here, when for example the diff spins with x-revolutions both front axles should do the same. If 1 wheel has no grip the diff uncouples and sends all the power there (least resistance), abs/vdc computer sees that and brakes (abs) the spinning wheel -> to transfer power to the other front wheel. (electronic diff 'lock') Parking brake could be on front wheels these days but I have no idea Strange thing here is both front and back Left abs sensor is messing up. Could be that the fall back of missing front speed sensor is the abs wheel speed sensor between front and rear. Maybe you also have a somewhat deflated tire. Quote Link to comment Share on other sites More sharing options...
