sirtokesalot Posted November 6, 2019 Share Posted November 6, 2019 well i think ive decided to throw myself into hell and i want the digital hvac controls. ive been separating the hvac wiring from the main harnesses on a parts h6 for a while now slowly making progress if anyone would like updates on this as it goes ill keep updating it but it will likely be a slow process and may end up with the project going on hold for a bit at times. i will likely end up running into some issues i will need help getting past with wiring as well when i get to some stuff like the a/c but im trying to maker it be a stand alone setup so i dont have to cut or modify the factory wiring but rather install a secondary harness just for the hvac control Link to comment Share on other sites More sharing options...
lmdew Posted November 7, 2019 Share Posted November 7, 2019 What's driving the change? Link to comment Share on other sites More sharing options...
sirtokesalot Posted November 7, 2019 Author Share Posted November 7, 2019 On 11/7/2019 at 12:06 AM, lmdew said: What's driving the change? Expand i like the look of the digital one better Link to comment Share on other sites More sharing options...
el_freddo Posted November 7, 2019 Share Posted November 7, 2019 (edited) Have you sussed out whether or not you need to swap heater boxes, or are the actuators easily retro fitted/the system uses what’s already there? Cheers Bennie Edited November 7, 2019 by el_freddo Link to comment Share on other sites More sharing options...
sirtokesalot Posted November 7, 2019 Author Share Posted November 7, 2019 ive learned i can use the box that's there and just ad a few things from the other box witch i do have in the part car. there's a few sensors that i need to ad and id need to build a circuit to control the a/c compressor witch i think would be the hardest part of it. ive been basing it from this post here. https://sl-i.net/FORUM/showthread.php?19317-Converting-2000-Legacy-GT-to-Automatic-Climate-Control Link to comment Share on other sites More sharing options...
