Lifted glwagon Posted November 26, 2019 Share Posted November 26, 2019 So I have an 88 gl wagon and it needs a new driveshaft, I also have a 86gl sedan, will the driveshaft from the sedan work in the wagon? Because I really dont want to spend 400 bucks on a new one haha Link to comment Share on other sites More sharing options...
el_freddo Posted November 26, 2019 Share Posted November 26, 2019 If it’s a front driveshaft for the front end and both are carb then yes. Front and rear shafts are not interchangeable. Cheers Bennie Link to comment Share on other sites More sharing options...
Lifted glwagon Posted November 26, 2019 Author Share Posted November 26, 2019 So what youre saying is that I cant use the rear drive shaft from the transmission to the axle from the sedan 86 and put it in the wagon 88 Link to comment Share on other sites More sharing options...
RMS Posted November 26, 2019 Share Posted November 26, 2019 drive shaft two piece. trans to steady bearing. steady bearing to diff . Link to comment Share on other sites More sharing options...
Numbchux Posted November 26, 2019 Share Posted November 26, 2019 On 11/26/2019 at 4:23 PM, Lifted glwagon said: So what youre saying is that I cant use the rear drive shaft from the transmission to the axle from the sedan 86 and put it in the wagon 88 Expand No, in other parts of the world, a "driveshaft" is the axle shaft from the transmission/diff out to the hub, so that's what he's talking about. As long as it's an EA82 sedan ('85+ in the US) with the same transmission, yes, it'll work just fine. Link to comment Share on other sites More sharing options...
Lifted glwagon Posted November 27, 2019 Author Share Posted November 27, 2019 Thats what I was thinking because I measured the wheelbase length wise on both cars and it matches haha thanks a bunch guys Link to comment Share on other sites More sharing options...
el_freddo Posted November 27, 2019 Share Posted November 27, 2019 Hehehe... tailshaft/prop shaft. Now I get what you were asking! What Numchux said Cheers Bennie Link to comment Share on other sites More sharing options...
