FaceChoklad Posted November 26, 2019 Share Posted November 26, 2019 As the title suggest i am curious about getting more power from my 89 Subaru Brat. I've been thinking about an ej swap but I'm in love with the ea 81 and would like to refrain from engine swapping. Any ways to pump some power from this little thing? Link to comment Share on other sites More sharing options...
DaveT Posted November 26, 2019 Share Posted November 26, 2019 Anything simple and low cost gives you small amounts. Anything complicated and expensive is going to consume time and NLA parts. EJ swap is a big project and is 40% HP increase with no engine reliability penalty, and parts are available. How you use that power may be stressful to the rest of the driveline... Link to comment Share on other sites More sharing options...
carfreak85 Posted November 26, 2019 Share Posted November 26, 2019 I wouldn't recommend running an EJ in front of an EA transmission, you're asking for trouble long term. There are some companies out there that manufacture go-fast parts for the EA81. There used to be a handful of experimental engine builders who had parts for the EA81 as well as Paeco Industries. Link to comment Share on other sites More sharing options...
Steptoe Posted November 26, 2019 Share Posted November 26, 2019 Where do you want this power? Low speed, high speed, seat of pants, EA81T Twin Hitachi carbs on manifold Just a tune can help Those that EJ seem to also go EA82 five speed conversion Hang around the aircraft engine sites if any left. Somewhere out there are special heads SUB4 New Zealand, roller rockers, cast alloy rocker covers. SUB4 used to run a Brumby with their engine components in it. 16/56 camshaft profile was best I did, until I went twin carbs, then EA82 Y pipe EA82 5 MT Then the best thing I did was put an EA82 in Link to comment Share on other sites More sharing options...
el_freddo Posted November 27, 2019 Share Posted November 27, 2019 15 hours ago, Steptoe said: Those that EJ seem to also go EA82 five speed conversion The EA82 5spd will handle the EJ22 power just fine so long as you’re not trying to turn massively oversized wheels. 15 hours ago, Steptoe said: Then the best thing I did was put an EA82 in Blasphemy!! Should never happen. Many good Brumbys destroyed over here with a hammer trying to fit an EA82 into the EA81 engine bay. Cheers Bennie Link to comment Share on other sites More sharing options...
