Tnicholson Posted November 26, 2019 Share Posted November 26, 2019 My daughter has a 97 Subaru Outback (2.5). She's been having issues with it starting. I replaced the starter (had the new one checked to make sure it's good), new battery, new terminals and cables. It will run for a couple days then it doesn't want to start, just makes a ticking sound. If we let it sit for a while or jump it, it will start right up. Ignition Coil possibly??? At times the check engine light will come on after it starts and there is a little lag in the starting. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 27, 2019 Share Posted November 27, 2019 scan for codes. seems like a 'dark current' power drain to me. You could check the current draw, if high, start pulling fuses to try to pin-down the circuit responsible. does it have a replacementradio? check for stuck CD. Does it have an amplifier? make sure it turns off completely - double check any aftermarket electronics. 2 Link to comment Share on other sites More sharing options...
brus brother Posted November 27, 2019 Share Posted November 27, 2019 I know you said you tested it but was the starter oem or aftermarket rebuild? When it doesn't start try tapping the starter with a long piece of wood while turning the key. Check the alternator? 3 Link to comment Share on other sites More sharing options...
Rampage Posted November 27, 2019 Share Posted November 27, 2019 On 11/26/2019 at 11:03 PM, Tnicholson said: just makes a ticking sound. Expand Is that one click or a constant series of clicks when turning the key to start position? When you turn the key to start, if the sound is like a chatter, that is usually the sign of a low battery. One click means the starter solenoid is not getting enough voltage or current to pull in completely to run the starter motor. First I would check the voltage on the battery ( 12 volts ) then with the engine running and the lights on, it should be at least 13.8 volts at an idle. If you don't have a volt meter you can turn the headlights on and then try to start it. It the lights go out or get very dim the battery is not charged so have the alternator checked. Link to comment Share on other sites More sharing options...
ThosL Posted November 29, 2019 Share Posted November 29, 2019 Ignition coils are not expensive, if used OE or new Herko, etc.. I don't know how bad that would have to be to not even start. If you put in a starter, what was the previous history of the car and starter? Who installed the new one? Link to comment Share on other sites More sharing options...
lmdew Posted November 29, 2019 Share Posted November 29, 2019 If the starter is just ticking, not turning the engine over it has nothing to do with the coil. Make sure you check the grounds! Load Pro is a great tool. Check it out on you tube. I had one fellow with a 96 legacy, would not charge. After several used Alt, I finally got him to bring it over. The main ground wire bolt going to the engine bracket was not tight and was burnt an pitted. Replace the cable and bracket and he Loved his Subaru again. 1 Link to comment Share on other sites More sharing options...
idosubaru Posted November 30, 2019 Share Posted November 30, 2019 On 11/26/2019 at 11:03 PM, Tnicholson said: or jump it, it will start right up. Ignition Coil possibly??? Expand This looks obvious - the battery is too low to start the car. 1. alternator or connections/wiring to battery. 2. Separating crank pulley 3. parasitic draw Link to comment Share on other sites More sharing options...
idosubaru Posted November 30, 2019 Share Posted November 30, 2019 Test alt output. If it’s an aftermarket alternator they’re low grade or garbage. Starters and alternators are pointless waste of cash at the aftermarket Parts stores. subaru dealer has an $80 alt for that car. 1 Link to comment Share on other sites More sharing options...
