ea82 eating oil
RMS
well I just had the mighty ea82 down too the short block new gaskets and seals but its still consuming a lot of oil. rear hatch is speckled with soot.
with the heads off I did the valve seals but cheeped out on doing the guides.  the guides felt ok but one exhaust valve was a bit tight.
I used my thumbs of steel to seat the valve seals and used the little plastic sleeve  when installing and used lots of lube.
could I have not seated the valve stem seals all the way ?  could the guides be so worn that new seals would not have helped ?
or could it be the rings?  there was a small step on the top of the bore ...
ea82 consuming about 1L for every 400 km
