logic23 Posted December 4, 2019 Share Posted December 4, 2019 (edited) Hello group, I have a friends 2011 outback with a N/A 2.5 that needs an engine. I have a low mileage 2008 JDM N/A 2.5 engine that i wondered would fit. The valve covers will need swapped so that the coil packs will have somewere to bolt. There is also the obvious peripherals like the intake that i will need to swap. Any help is appreciated, Craig Edited December 5, 2019 by logic23 Link to comment Share on other sites More sharing options...
logic23 Posted December 5, 2019 Author Share Posted December 5, 2019 I haven't gotten too far with this project but I already found one difference: The spark plug tubes are about an 1/8 shorter on the 2011 engine. When you go to bolt the valve covers down you are really squishing the spark plug tube seal against the valve cover. Ill take some pics once i get the 2011 engine out and see if there are other differences. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 5, 2019 Share Posted December 5, 2019 The short block will work. But everything else is different. GD Link to comment Share on other sites More sharing options...
logic23 Posted December 5, 2019 Author Share Posted December 5, 2019 Shortblock as in the lower end and heads ? Link to comment Share on other sites More sharing options...
el_freddo Posted December 5, 2019 Share Posted December 5, 2019 Short block = block only. Long block = block and heads, nothing else. What GD is saying is that you need to take the 2011 heads and fit them to the 2008 block. Job done. Cheers Bennie Link to comment Share on other sites More sharing options...
logic23 Posted December 5, 2019 Author Share Posted December 5, 2019 The issue with the 2011 is that it jumped time and bent valves. Thanks Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 5, 2019 Share Posted December 5, 2019 Then you likely need to replace the valves. They are cheap. I don't believe the 08 heads will work. I would just fix the 11 engine. Valves are cheap. GD Link to comment Share on other sites More sharing options...
idosubaru Posted December 6, 2019 Share Posted December 6, 2019 12 hours ago, logic23 said: The issue with the 2011 is that it jumped time and bent valves. Thanks Buy a set of used heads and you’re done. Ive replaced valves, but they can be mind numbing if you dont have a spring compressor fit for EJ25s. the auto parts store loaner ones don’t work for all the valves due to side clearance. None of the three valve compressor tools I’ve used work or require exceptional work arounds and gobs of time. I built a crude tool to do them. If you don’t have a compressor good for EJ25s it’ll be a time sucking brouhaha. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 6, 2019 Share Posted December 6, 2019 Heads for an 11 will be $$$$$. Gentlemen. I present the VALVEMASTER! https://www.toyotool.com/ GD Link to comment Share on other sites More sharing options...
el_freddo Posted December 6, 2019 Share Posted December 6, 2019 I can’t work out how that valve master system works - is there another piece require to fit one of those tools into? I’ll keep it simple at my end - I’ve used this a number of times successfully: https://www.amazon.com/GEARWRENCH-2078D-Universal-Overhead-Compressor/dp/B0002STSGC#immersive-view_1575671478784 pretty easy to use on EJ251 heads, it’d be a different story on DOHC heads I reckon. I didn’t get mine from Amazon, I got it from a local store. Cheers Bennie Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 6, 2019 Share Posted December 6, 2019 You have to watch the video. You just smack it with a hammer to remove the keepers, and you give it a sharp downward push to install them. It takes seconds. GD Link to comment Share on other sites More sharing options...
