Dano6 Posted December 6, 2019 Share Posted December 6, 2019 I just installed a used VDC module and ABS pump with all exact matching numbers on my Impreza 2013. Is it plug and play type? Are the light in the cluster should shut them self off without any action by my self? Thanks Link to comment Share on other sites More sharing options...
gbhrps Posted December 8, 2019 Share Posted December 8, 2019 Dano6, Yes and no? The ABS Module, as part of the braking system, will need to be bled, I suspect, from all 4 wheels. The VDC Module just requires plugging in ..... but it may require more than just that. As well, your DTC codes may need to be deleated by disconnecting the battery, or a scan tool may be required. This is a link to a FREE download of the factory service manual for your car. Download the the first two listed (they may be the same, or not) and do some searching to find the answers you need. They're good to have anyway. Good Luck! http://jdmfsm.info/Auto/Japan/Subaru/Impreza/2013/ Link to comment Share on other sites More sharing options...
Dano6 Posted December 8, 2019 Author Share Posted December 8, 2019 Thank you very much!!! Everything is just fine now!!! Link to comment Share on other sites More sharing options...
