Help please, Fan thermoswitch size?
Anybody know the thermo-switch size on the EA82 radiator? Getting a fan kit with a switch that taps into the radiator as I dont trust probes. the kit comes with a 1/8NPT switch as well as an adapter bung that goes to 3/8NPT. Are any of these sizes going to work? just want to make sure i dont blow money and order the wrong thing.
Only way you're going to make it happen with an aftermarket switch in the radiator is to take an old switch,  cut it down, drill it out and tap it to 1/8 NPT and that will only work if the inside of the old switch is solid. You could also find the right size metric bolt and do the same thing. That would be the way I would go.
