sadarahu Posted December 11, 2019 Share Posted December 11, 2019 (edited) Sub.Forester 2007 /115k Since a few days I have CRUISE CONTROL message blinking and along with that CHECK ENGINE. After weekend (2 days no driving) it went off, then Monday after o.5hr driving came back again. Of course I cannot turn on/off cruise controll and any of its features are not working. I was wondering if there is something that possibly could be reset ? Fuse? Relay ? switch ? etc? Any ideas what might be causing it ? Edited December 11, 2019 by sadarahu Link to comment Share on other sites More sharing options...
lmdew Posted December 12, 2019 Share Posted December 12, 2019 There is a reason for both lights at the same time. Owners manual would be the best source. From the Web: Q. My check engine light came on and or my Cruise control light is flashing, is My Subaru ok to drive? A. The check engine light can come on for one of many reasons, as such there is really no way to know if its for a loose gas cap or something much more serious without at a minimum a code scan. Starting in 2005 Subaru commanded the Cruise light to flash as well as disabling the cruise control to get your attention. As long as the light is on steady and there is no apparent change in the way your Subaru is performing its most likely ok to drive. Get the ECU codes! Link to comment Share on other sites More sharing options...
brus brother Posted December 12, 2019 Share Posted December 12, 2019 (edited) as above suggested got to autozone, advanced auto etc and they will read the codes for free. come back here with whatever the code is for suggestions on how to proceed. there may be more than one code. bring it on. I use something like THIS that saves me a drive to the parts stores. also handy for clearing codes and getting readiness set for passing emissions ;-) Edited December 12, 2019 by brus brother Link to comment Share on other sites More sharing options...
Mike104 Posted December 13, 2019 Share Posted December 13, 2019 You can also disconnect the negative battery terminal for 5 minutes to clear the code. If it is a continuing fault (check engine light comes on again) take it to a chain auto parts store to get the code read (make sure to get the PXXX number) and come back here for help. Link to comment Share on other sites More sharing options...
uniberp1 Posted December 16, 2019 Share Posted December 16, 2019 Have you ever changed the spark plugs? Every 40k miles is what is recommended. Link to comment Share on other sites More sharing options...
