ABS VDC warning lights on, need help with code flashes.
The car seems to run fine but I've got ABS and VDC lights on.  I put in the connecting wire to get the codes, I would like help with "reading the code".  Here's the flash pattern.
 I am unsure if a count every flash.    The pattern repeats, and is made of long flashes (I) and short ones (i) and spaces..   Here's my break down. Long one, short one, space, , 7 long, 1short, space,  7long, 4 short, space,  four long, 9 short then quickly repeat.  If I count all of them I get 34,  Front left outlet valve?
Here's a link to the codes.
thanks in advance.
Yes, the alternator looks like it has been replaced.  I've owned the car for around four years and can't remember if I did it, but if I did it was years ago.  I usually get NAPA parts.  Should I check the voltage after disconnection the wires?  Is the ABS disabled currently?
