Laurie Brown Posted December 14, 2019 Share Posted December 14, 2019 Hi; I have a 92 Legacy that has developed starting problems. It was fine during summer if you did a cold start without pressing on the accelerator at all. Then when it got cold outside, it began to not start. Now it will only start with the accelerator pedal pressed down on the floor. With the key 'on' but not starting, the electric fuel pump is at 40 lbs. With the engine running, it's at 50 lbs. If the fuel line is pinched, it goes to 80 lbs. After running the engine for 10 minutes and then letting the car set for about 30 minutes, the engine starts fine with no throttle. Husband just put in a new fuel filter after these problems started. Twelve months ago he replaced the fuel regulator, fuel pump relay switch, coolant thermosensor and it worked good for a year. He has not rechecked the coolant thermosensor. Any guesses as to what the problem is? Having a car that starts reliably is very important to me as I'm a hospice volunteer. Thank you! Quote Link to comment Share on other sites More sharing options...
heartless Posted December 15, 2019 Share Posted December 15, 2019 holding the pedal to the floor when cranking is a "clear flooded condition" signal to the ECU, this signals the ECU to shut down the fuel pump temporarily... you may have one or more injectors leaking. 1 Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 15, 2019 Share Posted December 15, 2019 Coolant temp sensor is a suspect. Check the resistance on it. Best to get one from Subaru. And yeah WOT is clear-flood on most fuel injected engines so you do appear to have a flooding condition. GD 1 Quote Link to comment Share on other sites More sharing options...
