gritle Posted January 9, 2020 Share Posted January 9, 2020 (edited) I drive a 2005 outback its got 197000 miles on it. Within the past 12 months, there have been three times when the engine just straight up stopped and the car shut down. I had bumped the gear into neutral Once while driving down the highway at about 65 or so miles an hour I had bumped the gear into neutral and it stopped. I was able to use the breaks and pull to the side, stopped and started the car again. I drove the rest of my way with no problem. That was last Jan or Feb. Then in November, the engine stopped when I turned off a highway. there seemed to be a bump in the road but nothing that happened in the car. A third time this happened in December. There was a rattling sound so I jiggled my leys with the back of my hand and the engine stopped and car shutoff. I was again able to pull over, stop and start the car with no issue. Has anything like this happened to anybody else? Is this a concern or just some flukes from bumping into neutral and rattling the keys? I'm not too worried I'll just be sure not to bump anything again I guess. Thanks. Edited January 9, 2020 by gritle Link to comment Share on other sites More sharing options...
Rampage Posted January 9, 2020 Share Posted January 9, 2020 Since this is a random problem, I think I would swap the Ignition Switch first. 26 bucks at RockAuto, why not. The problem could be anything, like the Main relay, or a corroded contact in a plug somewhere and to find that would take some time. Link to comment Share on other sites More sharing options...
rverdoold Posted January 9, 2020 Share Posted January 9, 2020 There is a Recall in europe on the fuel pump connector for the 2003 - 2009 legacy/outback series! Link to comment Share on other sites More sharing options...
el_freddo Posted January 10, 2020 Share Posted January 10, 2020 Fuel pump would give a dying engine and loss of power feeling before stalling out. It doesn’t give a direct engine cut feeling/situation. I’d also be checking earth points, make sure they’re all clean and solid. Cheers Bennie Link to comment Share on other sites More sharing options...
