4loyales Posted January 9, 2020 Share Posted January 9, 2020 Hello everyone. Accidentially let the protection on my coolant drop too low and had a couple cold nights pop the freeze plugs on my Subie. Motor starts and runs fine, as long as coolant is in the vehicle. Need some guidance on R&R for the freeze plugs. Never done them before, so as much detail as possible would be appreciate. TIA Link to comment Share on other sites More sharing options...
DaveT Posted January 10, 2020 Share Posted January 10, 2020 They are on the top of the heads. If you have EA82 engine.... Have to at least take off the cam covers to maybe see them. To get at them, might have to remove the carriers also. I have never tested them with cold temps and water. Don't remember reading anyone having to deal with them either. . Link to comment Share on other sites More sharing options...
el_freddo Posted January 10, 2020 Share Posted January 10, 2020 If the Welch/freeze plug have popped out your engine wouldn’t run as it would be full of coolant. You oil will be mixed with coolant. What makes you think you’ve popped these plugs out and that it’s not another coolant loss issue? The radiator would be more likely to crack before the block was effected. I think more investigating is needed. Cheers Bennie Link to comment Share on other sites More sharing options...
4loyales Posted January 14, 2020 Author Share Posted January 14, 2020 On 1/10/2020 at 2:59 PM, el_freddo said: If the Welch/freeze plug have popped out your engine wouldn’t run as it would be full of coolant. You oil will be mixed with coolant. What makes you think you’ve popped these plugs out and that it’s not another coolant loss issue? The radiator would be more likely to crack before the block was effected. I think more investigating is needed. Cheers Bennie El_freddo, excellent instincts. Upon closer inspection I found a damaged hose, a little L shaped number from the throttle body back to the coolant line. Replaced that and things seem to be working properly. Appreciate the guidance everyone. Link to comment Share on other sites More sharing options...
DaveT Posted January 14, 2020 Share Posted January 14, 2020 That is one of a few coolant hoses that many overlook. There are 7 hoses involved in the cooling system for an EA82 enine. They should all be treated as you would any other radiator hose, they all age similarly. Link to comment Share on other sites More sharing options...
el_freddo Posted January 15, 2020 Share Posted January 15, 2020 2 hours ago, 4loyales said: El_freddo, excellent instincts. Upon closer inspection I found a damaged hose, a little L shaped number from the throttle body back to the coolant line. Replaced that and things seem to be working properly. Appreciate the guidance everyone. Thanks mate, not instincts - experience after buying a brumby “that just stopped onthe way to work”. Popped Welch plug filled the content of the cooling system into the engine. We got 20L of water oil and sludge out of the little EA81. This is what we found once the heads were removed: One welch plug dropped out. Cheers Bennie Link to comment Share on other sites More sharing options...
