brus brother Posted January 29, 2020 Share Posted January 29, 2020 (edited) 05 Outback 200K miles OK so I have had the P2098 for the past few months and now I am noticing a serious oil leak. I will crawl under the car tomorrow and try and see if I can track down the leak but in the meanwhile, is the valve cover leak capable of producing a vacuum leak and pesky P2098? Edited January 30, 2020 by brus brother Link to comment Share on other sites More sharing options...
3Pin Posted January 29, 2020 Share Posted January 29, 2020 They could be related, ,but it could head gaskets leaking and the issue that makes p0298 happen. OBD2 Code P0298 Subaru definition:Indicates the Engine Oil Temperature Protection (EOT) strategy in the Power Train Control Module (PCM) has been activated. This temporarily prohibits high engine speed operation by disabling injectors, reducing the risk of engine damage from high engine oil temperature. Note: On engines which are equipped with an oil temperature sensor, the PCM reads oil temperature to determine if it is excessive. When an oil temperature sensor is not present, the PCM uses an oil algorithm to infer actual temperature. Engine shutdown strategy function is the same on vehicles with and without oil temperature sensors. Link to comment Share on other sites More sharing options...
brus brother Posted January 29, 2020 Author Share Posted January 29, 2020 3Pin the code I am getting is P2098 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 29, 2020 Share Posted January 29, 2020 2098 is a post cat fuel trim code. Usually this is an exhaust leak. Not related to oil leaks. Valve covers leaking oil generally do not constitute enough of a vacuum leak to be measurable. GD Link to comment Share on other sites More sharing options...
3Pin Posted January 29, 2020 Share Posted January 29, 2020 thanks, my eyes are getting old and tired. Agree with GD though. Link to comment Share on other sites More sharing options...
brus brother Posted January 29, 2020 Author Share Posted January 29, 2020 (edited) there are 5 sensors total (2AF precat, 2 O2 sensors, one on each front cat, and one O2 sensor on the rear cat) there is a small exhaust leak at the joint where the passenger cat (bank 1) joins the driver cat (bank 2) and before the rear cat. I am just curious if this could be the culprit since while not audible, if I plug the exhaust and push air back up with a shop vac, I can see air bubbles if I spray water on the joint. If this is indeed the location of the cause of the P2098, why would this read as a bank 2 error? Edited January 29, 2020 by brus brother Link to comment Share on other sites More sharing options...
brus brother Posted January 30, 2020 Author Share Posted January 30, 2020 Does anyone have the stepwise flow diagram in diagnosing the P2098 for Subaru Outback 05 Auto 2.5 non turbo? Link to comment Share on other sites More sharing options...
brus brother Posted January 30, 2020 Author Share Posted January 30, 2020 found it LINK Link to comment Share on other sites More sharing options...
MyFirstOutback Posted August 16, 2020 Share Posted August 16, 2020 On 1/29/2020 at 9:12 PM, brus brother said: there are 5 sensors total (2AF precat, 2 O2 sensors, one on each front cat, and one O2 sensor on the rear cat) there is a small exhaust leak at the joint where the passenger cat (bank 1) joins the driver cat (bank 2) and before the rear cat. I am just curious if this could be the culprit since while not audible, if I plug the exhaust and push air back up with a shop vac, I can see air bubbles if I spray water on the joint. If this is indeed the location of the cause of the P2098, why would this read as a bank 2 error? Expand I also have an 05 OBW and started getting the same code. Was the leak the issue? If I reset it, the CEL won't come back on until it's been driven some. Maybe 25-100 mi. I hope a leak is all it is instead of >$100 for a sensor! Link to comment Share on other sites More sharing options...
brus brother Posted August 16, 2020 Author Share Posted August 16, 2020 Not in my case. I had installed a resistor on the front O2 sensor trying to trick the ecu into ignoring the pesky P0420 code. Removed the resistor and the P2098 went away... Back to the P0420 which I know how to deal with to pass emissions. Good luck. Link to comment Share on other sites More sharing options...
