2013 OB goes FORWARD in reverse and wont roll in neutral...?!
Light wreck pinched the trans line up front and puked fluid.
I refilled it and it drives in drive, goes *forward* when in reverse, and goes nowhere in neutral - it won’t even drift in neutral?!  What?  How can you “blow” neutral?
Is this transmission hosed from puking or has air in the fluid from being emptied or am I missing something?
I ASSume 2.5, CVT?
Does it go into Park (engage parking prawl)?
What fluid did you use, and did you put it in the right place (fill plug on the side)?
I know these can be a bear to get all the air out (best done level, warm and running, which is hard to do without a hoist), but I wouldn't think an air pocket would default to drive.
You got it - CVT, 2.5, correct fill hole, and Amsoil CVT fluid that GD uses.
Like you suggest - Subaru mentions temperature and adding quantities at a time/cycling with engine running. I just topped it off and ignored that
I did briefly shift but didn’t cycle through gears much at all so maybe it’ll smooth out topping it off again and looking at those procedures.
Edited by idosubaru
