steve56 Posted February 6, 2020 Share Posted February 6, 2020 Have 09 Legacy. Can I use oil pan bolts to put the separator plate back on the block? A couple the original bolts heads stripped when removing the separator plate. Link to comment Share on other sites More sharing options...
heartless Posted February 6, 2020 Share Posted February 6, 2020 i dont think so they need to be flush with the surface or they might interfere Link to comment Share on other sites More sharing options...
steve56 Posted February 6, 2020 Author Share Posted February 6, 2020 20 minutes ago, heartless said: i dont think so they need to be flush with the surface or they might interfere The original bolts have a curved head so their are not flush. Thought the older separator plate was fastened with bolts. Link to comment Share on other sites More sharing options...
el_freddo Posted February 6, 2020 Share Posted February 6, 2020 If you have a tin plate you might be able to do it. If you have the cast alloy plate, you’ll need the countersunk screws to make it all work with flywheel clearances etc. Cheers Bennie 1 Link to comment Share on other sites More sharing options...
Numbchux Posted February 6, 2020 Share Posted February 6, 2020 6 hours ago, el_freddo said: If you have a tin plate you might be able to do it. If you have the cast alloy plate, you’ll need the countersunk screws to make it all work with flywheel clearances etc. Cheers Bennie This. The cast alloy and plastic ones use countersunk hardware because the plate is much thicker. The plate steel ones use a conventional bolt. If you've got a dealer nearby, go spend $5 and get the right ones. The dealer I worked at always stocked a few sets as we would frequently retrofit the new plate in place of the plastic ones. 1 Link to comment Share on other sites More sharing options...
