jltorres179 Posted February 9, 2020 Share Posted February 9, 2020 Hi all, I'm hoping I can get some help on this problem that's got me completely stumped. So a breakdown of my problem: - Blinkers won't turn on in the dash or the bulbs and when I try to turn them on, there is a fast electrical sounding clicking somewhere in the dash or underneath it - After a few minutes of the car being on, the A/T light will start flashing and the car will refuse to shift into or out of park/reverse - I changed the relay and it didn't do anything so I left it unplugged and it will immediately not shift after turning on - I gave power directly to the wiring through the bulb and the front and back flashers turned on perfectly If anyone has heard of any fixes for this or has had a similar problem I would really appreciate any info! Link to comment Share on other sites More sharing options...
somick Posted February 10, 2020 Share Posted February 10, 2020 Any codes? Link to comment Share on other sites More sharing options...
Cougar Posted February 16, 2020 Share Posted February 16, 2020 It sounds like you may have a bad connection to power on the supply line to the flasher line. I assume the sound you are hearing is the flasher unit. Does one side of the blinkers work? Link to comment Share on other sites More sharing options...
