Cormfra Posted April 4, 2020 Author Share Posted April 4, 2020 Positive on both sides of the ignition coil Link to comment Share on other sites More sharing options...
Cormfra Posted April 5, 2020 Author Share Posted April 5, 2020 Okay so it should spark if there voltage on there side of the ignition coil correct and what would cause it to not spark even though there reading 12 on both sides. there are other random stuff not working on the car I’m wondering could it be something with the ecu Link to comment Share on other sites More sharing options...
naru2 Posted April 5, 2020 Share Posted April 5, 2020 Bad coil-does it work on another car? Or more likely,no connection to ground thru the transistor. Maybe no ignition pulses from the ECU on the WY wire to the transistor plug.(you need a LED style test light to see these) You never said if there were any trouble codes. Link to comment Share on other sites More sharing options...
Cormfra Posted April 6, 2020 Author Share Posted April 6, 2020 I have the test light I’ll try that tomorrow it should pluses when cranking brand new coil Link to comment Share on other sites More sharing options...
Cormfra Posted May 19, 2020 Author Share Posted May 19, 2020 Sorry I haven’t been on here for awhile there is no pulse does this mean there something wrong with my ecu there are no codes Link to comment Share on other sites More sharing options...
DaveT Posted May 21, 2020 Share Posted May 21, 2020 The ECU code LED should be blinking an all is ok code with the key in run position. Does that happen? Link to comment Share on other sites More sharing options...
Cormfra Posted May 22, 2020 Author Share Posted May 22, 2020 I will double check but there is no blink Link to comment Share on other sites More sharing options...
