Just Say No to Enginetech head gaskets
When I rebuilt my '99 OBW's EJ25D last winter I bought the Enginetech kit from Rock.  Convenience, you know, all the pieces in one box at a good price.  First thing that was wrong was the ring sizes, but that was my fault - I didn't know that they varied, so I had to buy the right set, as it was too late to return the wrong ones.  Then I found that the head bolts, um, could have been straighter... but they worked.  And I was fully aware that the head gaskets were cheapies, and not MLM, but figured what the hell, it's the first time I'm rebuilding one of these things from the ground up, so it's all an experiment anyway.
The experiment turned out well, it seemed.  Ran flawlessly for the better part of a year, including an impromptu 5000-mile round trip to New York in November after I wasted two months trying to find someone to tow a sailboat from Long Island to Montana.
Yesterday my wife got home and reported that the heater was sporadically blowing cold.  Sure enough, bubbles in the coolant tank.  I'll be ordering up a proper set of MLMs today, but could really have done without the hassle, esp. since it's still pretty cold here.
Grrr.
Other than genuine Subaru can we please start and continually update a sticky that promotes acceptable kits or combination of genuine SOA (i.e. belt) with other kit components. It can also contain warnings of bad experiences.
I recall Gates had good ratings until made in China appeared stamped on parts marketed as made in Japan. I am also old enough to recall when "made In Japan" was a mark of junk!
If the consensus is to go genuine Subaru all the way, then will start hunting down least expensive vendors, while taking care to somehow avoid the knock-offs as have surfaced with NGK plugs.
  On 2/13/2020 at 11:44 PM, ocei77 said:
The moral of this story is that if the price seems to be too good to be true it probably is.
Sorry you had to learn the hard way.
O.
Expand
Sorry?  How come?  Did you manufacture these gaskets?  If so, I'm going to have to put out a hit on you.  Otherwise, you don't have anything to be sorry for.
Sure, this is annoying.  But I knew going in that MLM is the right choice, that this was an experiment, and that you don't experiment unless you're okay with a negative result.  So I won't do it again, but I'm not losing sleep over it either.
  On 2/14/2020 at 1:42 AM, lmdew said:
Drop in a used 2.2 and be done with it.  I've been happy with every swap I've done.
Expand
As much as I love the EJ22 (when mated with a 5MT), it just wouldn't have the power to drive this thing with a 4EAT.  The 2.5/auto combo is underpowered enough for what I do, which is why I'm moving up to EZ30s.
Expand
I'd like to see that too - a thread for keeping track of what's good and what's junk.  For example, I've been really happy following GD's recommendations on non-OEM timing components, assembly lubes, etc., and it'd be helpful to everyone not to have to hunt through hundreds of threads and thousands of postings to find that info.
  • Like 1
  • 4 months later...
Addendum to this thread:  The other experiment I performed as part of the rebuild was with that little timing belt (guard? guide?) that's mounted just over the crank sprocket.  Well, it's there in the EJ22s, but I've never seen one in an EJ25 - but the mounts are there in the castings for it.  So I stuck one in.
Another bad idea.  When I opened the timing cover to begin the HG replacement, it was full of black rubber dust ground off the back side of the belt.  That crap was also deposited on the idler rollers, and the idlers are discoloured, just like you'd expect with a piece of metal that had been severely overheated (though that's obviously not what happened here).
I've ordered a new belt and won't  be trying that trick again.
Expand
Those are used only on manual transmission cars. Auto's never have them. It's to prevent a belt skip if the car is bumped while in gear. They serve no purpose on an auto car.
Regardless, the guide is not supposed to touch the belt - there is a clearance spec and if it's adhered to the belt will not touch the guide. The problem isn't the guide, it's the improper assembly, and if you want to get completely technical it shouldn't have been added to an auto car where it performs no function.
I very likely warned you about those gaskets......
Edited by GeneralDisorder
  • 1 month later...
Expand
Thanks - I didn't know why it was there on the MTs.  (Obviously) the guide shouldn't (and didn't) touch the belt - I can pull some lulus, but not one that stupid.  I suspect that the tensioner was getting sloppy and beginning to let the belt flap (hence the rubbing and wear), so I replaced it.  Car happy again now.
On the gaskets, I don't recall a specific warning, but I knew better and decided to experiment anyway, so I don't have a problem with taking my lumps.
