lmdew Posted July 7, 2004 Share Posted July 7, 2004 As far as I know it should work fine, but if anyone has tips or problems solved please let me know. Car I'm fixing 92 Wagon 1.8 3sp auto trans FWD is bad. Found a 88 GL wagon 1.8 5sp MT FWD I did this swap on a 93 to 92 Legacy but not the older Subarus. Things Needed: Trans and aft mounts Shifter and trim Clutch/brake box and pedals Clutch cable Clutch Kit flywheel and bolts Starter Speedo cable That should be it as far as I know. I believe the swap is straight forward. Thanks for the info Link to comment Share on other sites More sharing options...
MilesFox Posted July 7, 2004 Share Posted July 7, 2004 pretty much straight forward. 4wd to 4wd. try a 2wd to 4wd, more stuff! the pedal box and clutch cable will come out as a unit you need a DRIVESHAFT, any 5spd will fit, actually its only the front half thats different (5spd is longer) Link to comment Share on other sites More sharing options...
