Ionstorm66 Posted February 28, 2020 Share Posted February 28, 2020 Installed an aftermarket radio and it randomly turns on when opening and closing doors. I verified I have the constant and ignition power wired correctly. It dosent happen all the time, but I have noticed some times when I walk away or up to my car the radio connects Bluetooth, then starts playing music. Maybe something is floating or a switch bounce is causing noise on the ground/ignition. Link to comment Share on other sites More sharing options...
el_freddo Posted March 2, 2020 Share Posted March 2, 2020 Have you grounded the radio to a door switch wire? If that switch is dicky, it would explain the way it randomly turns on. Easy check is to open the door, have the radio turn on and push the door switch button and see if there’s any change. I’ve got a Liberty that does the opposite - open a door and the radio turns off. Same deal I’m sure, just wired differently. Cheers Bennie Link to comment Share on other sites More sharing options...
el_freddo Posted March 2, 2020 Share Posted March 2, 2020 PS: actually, grounding to the door switch wouldn’t work I don’t think. I’ve confused myself on this one now... Link to comment Share on other sites More sharing options...
