adot Posted February 29, 2020 Share Posted February 29, 2020 I let someone test drive my 87 GL last weekend and just noticed now that My belt is loose and I’m missing a part! It must have fallen off while they were driving it. The belt is clearly loose now. Could someone help me identify the part/part number so I can get this car back on the road? Any info out there would be much appreciated. Link to comment Share on other sites More sharing options...
lrgvanman Posted February 29, 2020 Share Posted February 29, 2020 (edited) Looks like the pressed on pulley that comes attached to the waterpump. If you have had it changed with a lifetime warranty, you'd likely be due a defective exchange, if not, you'll have to replace that waterpump. Looks caked with oily residue. I've never seen one detach but really haven't seen it all. Try not to drive it though. Your waterpump is non functional and WILL blow head gaskets and/or worse if it hasn't already! Edited February 29, 2020 by lrgvanman Link to comment Share on other sites More sharing options...
adot Posted February 29, 2020 Author Share Posted February 29, 2020 On 2/29/2020 at 6:21 PM, lrgvanman said: Looks like the pressed on pulley that comes attached to the waterpump. If you have had it changed with a lifetime warranty, you'd likely be due a defective exchange, if not, you'll have to replace that waterpump. Looks caked with oily residue. I've never seen one detach but really haven't seen it all. Try not to drive it though. Your waterpump is non functional and WILL blow head gaskets and/or worse if it hasn't already! Expand Thanks so much for the response! Luckily it was only driven around the block a few times so the engine didn’t get too hot. Looks like I have a water pump replacement to do for the first time. I’m looking forward to it 1 Link to comment Share on other sites More sharing options...
lrgvanman Posted February 29, 2020 Share Posted February 29, 2020 (edited) Best of luck to ya. I got a pump from rockauto; AISIN WPF-005 to keep it OEM for my 1984 ea81. https://www.rockauto.com/en/parts/aisin,WPF005,water+pump,2208 Edited February 29, 2020 by lrgvanman Link to comment Share on other sites More sharing options...
Steptoe Posted March 1, 2020 Share Posted March 1, 2020 Typo alert....all looks like an EA82 not EA81 You also need water pump belt pulley .... Link to comment Share on other sites More sharing options...
DaveT Posted March 1, 2020 Share Posted March 1, 2020 It ea81. Distributor is on th e front, left of center. I didn't realize the power steering pump was the same. Also, no timing belts or covers I can see in the pics. 1 Link to comment Share on other sites More sharing options...
