86 GL 4dr
The code 22 is speed sensor related. the factory rundown on testing it is rather crazy so I wont try to confuse you with it.
the code 24 is for the temp sensor. I would suspect this as your problem area.
I really dont know how the computer controled carbs work on a sube verry well so I will refrain from guessing.
of course you have checked all the basics like fuses and good clean grounds(to the motor too)?
