Ionstorm66 Posted March 3, 2020 Share Posted March 3, 2020 So I finally got the roof rack on so I slapped a gas can to finally see if the gas light worked. When it finally ran out I had no gas light, and when I filled it up it only took 12.3 gallons plus the gallon I put in out of the can. I ran out on flat ground and it wouldn't even idle. The manual says it should be 15.9 total and the light should turn on with 2.4 left. Is there a filter or something that may of fallen off the pickup? Link to comment Share on other sites More sharing options...
