3crows Posted March 10, 2020 Share Posted March 10, 2020 I need to replace the rear brake cylinders on my 1987 4wd wagon. Sounds like one or both are dragging. Can't find anything online that says specifically for 4wd wagon, only sedan. Will the sedan cylinders work? I hate to have to take it apart to get a part number until I have the right cylinders to replace them with. Link to comment Share on other sites More sharing options...
Subarule Posted March 10, 2020 Share Posted March 10, 2020 Don't know your model but take a look here. I entered 1987 4WD GL 1.8L H4 SOHC for the search. https://www.rockauto.com/en/catalog/subaru,1987,gl,1.8l+h4+sohc,1268478,brake+&+wheel+hub Link to comment Share on other sites More sharing options...
moosens Posted March 11, 2020 Share Posted March 11, 2020 Does anyone have or know of factory Parts Manuals online ? That would surely show if there are two different cylinders. 99% of me says they are the same from like 1977 through 1994 Loyale. But check the 1% for kicks. Link to comment Share on other sites More sharing options...
moosens Posted March 11, 2020 Share Posted March 11, 2020 And if I think of it I will check my 1985 FPM for ya. Link to comment Share on other sites More sharing options...
DaveT Posted March 11, 2020 Share Posted March 11, 2020 (edited) I am pretty sure - for wagons only - 86 through 94 are the same. Drum brakes, rear, 4wd vs fwd no difference. Somewhere before 86, they were not auto adjusting, but the difference a hole in the shoes, and a couple of other parts. I never compared the cylinders. Edited March 11, 2020 by DaveT Link to comment Share on other sites More sharing options...
naru2 Posted March 11, 2020 Share Posted March 11, 2020 They are not all the same. Wagons and 3Drs use 3/4",everything else 11/16" The smaller ones won`t work properly. 25177ga360 NLA at the dealer,but,I see some at rockauto. Link to comment Share on other sites More sharing options...
DaveT Posted March 11, 2020 Share Posted March 11, 2020 I was only thinking of the wagons, I edited my post, don't want anyone confused. Link to comment Share on other sites More sharing options...
3crows Posted March 15, 2020 Author Share Posted March 15, 2020 Looking online for compatibility, one seller indicated that the Dorman #W37418 was not compatible for my rig. I called and talked to a Dorman rep and he assured me that these are the proper replacement rear wheel cylinders for my 4wd wagon. I took a chance and bought 2 online. They are 3/4" bore and are not side specific One of the things I noticed when looking at pictures online was that some had 2 studs and nuts to hold the cylinder to the backing plate while others had 2 bolts. I crawled under my rig and found that mine has 2 bolts. So there's still the question as to whether the cylinders with the 2 studs and nuts would work as long as it had the 3/4"' bore and wasn't side specific since they otherwise look the same, at least in the pictures. So next week when it warms up around here I'll take thing apart. Link to comment Share on other sites More sharing options...
